Location of cabin fuse box - Roadtrek 190 Versatile
JohnMcNally
Aug 17, 2022
5
CA
HI, Anyone know where the cabin fuse box is on a 92 Dodge B250 Roadtrek 190 Versatile campervan? Thanks much!, John
until someone smart comes along... it is probably under a sofa/bench cabinet on the same side of the van as your coach battery.
if you see little circuit breakers, there are black or red tabs which pop out the side when they are tripped- push in to reset
****** just looked online at a video and that owner has a bunch of electrical in the outside storage on the
driver side
driver side
Thanks for the reply. Unfortunately, neither of those locations are where the fuse box is. It seems I've looked everywhere and cannot find it. What a mystery!
In my 1992D190V 250 next to the cabinet under the stove. The battery is under the floor of the passenger seat driver side. Hope this helps.
My 1998 190 Popular has the same fuse box shown above . It’s under the driver’s side bench in the dinette/bed area. My battery is under the floor in the ‘trunk’ in the far back left corner . There’s a 12x12 patch of carpet hiding it. If you crawl under the van yo can see they build a metal box to hide it below floor level.
Hope this helps.
Hope this helps.
Thanks so much - I found it!
Where are the fuseboxes for the van, as opposed to the 'camper'. I found one in glove box but am looking for the one that has the lighter fuse. Or...what are fixes for the lighter input? It used to work fine. Now doesn't. No fuses in glove box seem to be relevant and are not burned. ALso: Who has a map to that fuse box? thanks
a year would be helpful...
on my 2005 chev van there is a fusebox under the hood and another under the driver's seat.
both have plastic covers on which there is a sticker with a legend
1992 road trek 190
Hi !
Thanks! 1992 190 versatile
I looked under the.seat but there was nothing I could see or reveal. There is no legend under the cap in the glove box. :/
Is a fuse what would be the most likely cure.to fix the lighter input?
you will have to go to google
and detail whether this is a Dodge or Chevy van ( I think RT used both around that time-)
you'll also have to check the model year of the van- in most cases a "1992" RV is built on a 1991 chassis ( very common with our Class B's)
- being too stupid to read the manual when I had a problem on my 2001 gmc... I looked and searched wasted time and sweated and swore.
Eventually found out that I had a second fuse box behind a panel at the end of the dashboard... only accessible when the driver door is opened !
good luck
For the Dodge chassis fuse box, open the driver's door and pop off the panel on the side of the dash. The inside of the panel has the map.
Hi,
I looked and there is nothing that ‘pops out’. I could unscrew some stuff and try to get part of the dash off, but that seems like it would be too much?
For anyone else who might have ideas, it;s and looking for 2nd fuse box and if anyone has a pic of the map of fuses inside glove box that would be great too.
1992 190 Versatile Roadtrek, on a Dodge. I’ve looked under driver’s seat, tried to find somewhere by side of dash inside driver’s door. Trying to get the lighter input to work that is on the main dashboard. There is one in the ‘house’ of the camper and that does work.
Thanks thanks
Rebecca
Aside: How do I make a new post
I can not find the tab to make a post…can anyone direct me? I see
User CP, Registry, FAQ (hasn’t told me), Community, Calendar, New Posts (not here that I see), Search, Quick links
Where is “Make a post”??
Thanks!
