Making Toast
Members shared a wide range of solutions for making toast in camper vans, with the most popular methods being small electric toasters (often 2-slice models), stovetop toasting using frying pans or cast iron, and specialized camping toaster racks like the GSI Outdoors Glacier Stainless Steel Toaster. Several RVers noted that using electric toasters is feasible with inverters rated 750W or higher, but smoke alarms are a frequent nuisance, especially in compact spaces. Some members use air...
wbdmadvt
Mar 3, 2012
581
Morning toast is the wife’s favorite. What is everyone using to do toast in the camper van?
15C210P
I sometimes toast bread (and bagels) using a frying pan. With no oil, using an already well seasoned cast iron pan. You just put the bread on the pan, heat it up, and press down a bit on top of the bread until it browns, then flip it over and do the other side. It works well enough for me, though I am sure there are better ways!
Yeah - my RT 170 is a small space and the smoke alarm is right by the stove so it often goes off when I am cooking even though I always run the fan or vent.
I always try to remember to put the smoke alarm on the 3rd seat and run the fan when I cook. However, sometimes I have to be reminded by that piercing beeping noise if I forget. I do wonder if that's a common occurrence in campgrounds.
I saved this from Grandparents 1960 Lil' Loafer 12' trailer. Makes great toast!
A cheap 2 slice toaster that trips the smoke detector about third of the time. We have a 2000 watt inverter that handles the toaster easily and 4 slices of toast barely drops the battery level.
15C210P
I use these two-1-slice toaster plugged into my Jackery or if I’m plugged in, or the stove/grill top otherwise…and yes, don’t forget the smoke alarm!
15C210P
Our 2096 RoadTrek has a combo microwave/toaster/oven that does a decent job. If I have propane grill out I can use that too.
A small air fryer is your best friend. Toast... and a WHOLE LOT MORE!
(I use in my 2019C210P)
Pair that with the smallest Instant Pot... 3qt -- you can make anything!
Add in a portable sous vide circulator with a butane torch -- you REALLY can make anything!
My family have been making “spatulized toast” since the early 60’s spanning 3 generations. It started at our remote cottage and we’ve taken it on the road when camping.
Heat a pan on the stove, butter both sides of the bread, and brown the 2 sides like a grilled cheese. But flatten the H3LL out of it with a spatula!!! It come out golden brown, wafer thin, stiff, and crispy. Be careful with plastic spatulas. We’ve broken a few over the years. My Nona’s metal and bakelite one was the best.
I have a ninja toaster oven/airfryer that I sit on top of the gas burners. I had kind of a box built to give me an even surface. I never moves when traveling. I cook EVERYTHING in that thing. I have a induction hot plate that stores easy and I will use in inside and outside. off grid I will start the gen just long enought to cook. That plus the microwave and I have no problem cooking. But remember that you are on holidays so the less work the better.
Same for my bagels, except fried in butter...
