Michelin LTX MS2 Mileage Compared With Agilis Tires
Original Member Title: Another mileage data point on Michelin LTX MS2 tires
A member shared another mileage data point after switching from Agilis 265-75-16 tires to Michelin LTX MS2 265-70-17 tires on the same van and familiar routes. They reported the routes had historically returned about 14.5 mpg with the Agilis, while the MS2 tires have been consistently about 0.5 to 0.6 mpg higher, including a 300-mile trip at 15.16 mpg.
Members asked whether the vehicle computer had been recalibrated and whether tire size could explain the change. The original poster said...
As it turns out, we ran out of the good apples we get at an orchard on the SE Minnesota trip mentioned so when a good day showed up we did it again, but reversed the loop part direction do to a misidentified construction zone that didn't exist. Conditions were worse for gas mileage based on our history. Colder early, relatively high wind (15+), and I tried not to be overly careful to drive for best mileage. Again about 265 miles and a single fill at the same pump before and after.
This time we came in at 15.75 on Scangauge with the change to 5% fuel comp and the hand calculation came in at 15.74, so all the setting seem to be quite good if this is accurate (only one fill).
The Scangauge showed about a 1mpg increase once the tires, roads, and air heated up from the 40* start to 55+ after about 50 miles. Wind was side wind plus a bit of tailwind going out and opposite coming back. The direction we went this time makes for made for more headwind exposure because of less tree cover so may have and had a small reduction of mileage.
It is still looking like the is a .5-1.0mpg gain with tire change compared to the Agilis.
Spring trip next year will add higher speeds to the mix so it will be interesting to see how that changes things. It also tends to be a lot windier and hotter on that trip. I expect that the non linear higher wind resistant at higher speeds will increase at a faster rate and may reduce mileage, so probably will be closer to the Agilis by some amount as wind resistance is the larger part of the total resistance.
