markopolo-ClassB
I need some help with choosing the Tire PSI for my Michelin LTX/MS2 LT245/75R16 E
I'm using data from these sources:
MICHELIN Truck Tire Data Book
http://read.dmtmag.com/issue/58068
and here
http://www.michelintruck.com/assets/pdf ... taBook.pdf
Last time I checked my van weight it was:
Front: 4020 lbs
Rear: 3860 lbs
(not fully loaded)
So if I plan based on 4200 lbs front and 4600 lbs rear what tire pressure would you use? In the past I have done 60 or 65 front and 80 rear.
From the Michelin charts it looks like I could 50 psi front and 60 psi rear for soft ride. Am I missing something?
Would you go that low?
and here
Front: 4020 lbs
Rear: 3860 lbs
(not fully loaded)
