I think the synthetic oil arguments will go on forever
artyman:
I am neither a hater or a great lover of synthetics, so no huge bias, I hope.
I use both, and have success with both. 1992 Escort ran for 18.5 years, 210K miles, of ugly Minnesota commuting. I used Castrol dino oil in it, and when it went to the junk yard it would still go 10K miles without adding oil and never leaked. We went to synthetic in our small engine lawn tractor engine and hydro transmission and they run noticeably cooler.
I also have had issues with synthetic. Several older flat hydraulic lifter engines I have been around would have tappet noise on synthetic. I have seen the leaking issue, and it is not just in engines. I changed my 96 Buick Roadmaster 4L60E to the Dexron VI fluid and got a leak in a cooling line within weeks. Pan gaskets on both trans and engines seem to have issues if they are not the new reusable, inserted spacer, silicone type like we have on the 07 Chevy 6.0 engine. I quit using the regular gaskets on the trans pans a long time ago and use Right Stuff with no gasket, as it is the only way I can get rid of the leaks.
Synthetics have also morphed due to some rule changes in what can be called full synthetic, it appears. Nearly all the major brands that are called full synthetic are now group III oils, or mixes of III and IV, I have been told. Those would not have been able to be labeled full synthetic a few years ago. Again second hand information, but Amsoil and Royal Purple are both said to still be 100% group IV oils. Redline is said to be nearly all group V oil which is a different chemical group that is very slippery and tolerates substantially higher heat.
I did read some information a while ago, that was written by a chemist IIRC. I found it very interesting. His claim was that group II and III oils were pretty much neutral in affecting seal hardening and leaking (this is for rubber seals, not the composition types). Group IV oils were said to soften the rubber seals some, which could help some rotating seals a bit, or make them leak. Stationary seals could start to leak. Group V oils were said to slightly harden rubber seals, which could make the wear faster and leak if rotating, and have less affect on stationary ones. He also claimed that a mix of the IV and V would be the best, but I forget the ratio, saying it would get back to neutral on the sealing, but give a lot of the extra temp and lubrication of the group V to the stability of group IV. He even thought the Redline was putting some group IV into their oils lately, but had no data to prove it.
What we use;
07 Roadtrek (6.0, 4L80E) : Mobil1 5-30 in the engine, Dexron VI in the trans. Amsoil Dexron IV in the power steering hydoboost system (definite improvement), either Redline or Amsoil extreme duty rear differential oil.
09 Honda CRV: All Honda fluids except the engine oil which is Mobil1 5-30. Hondas seem to be very picky on their fluids, and I have seen just too many messed up with non Honda products in the trans and power steering.
96 Buick Roadmaster: (5.7 LT1, 4L60E) (130K miles) Castrol 5-30 oil, Dexron VI in trans, Redline or Amsoil rear gear oil, Redline power steering fluid.
John Deere lawn tractor (17hp air cooled Kawasaki): Redline 10-40 motorcycle oil, Redline 20-50 motorcycle oil in the hydo trans.
Of course, everyone has their own opinions on this topic, and always will!
