We have very poor internet choices and home where we live.
We have been using a Centurlink DSL through Velocity Internet that is 8meps rated, more typically about 7MEP. Is not really fast enough to stream much of anything and it expensive for what it is. Also glitches out a lot.
The only other wired choice is Comcast Internet the is cheaper, allegedly, and rated at 75MEP but actual is unknown for our neighborhood. Comcast is also only reliable as being in the bottom 2% of all companies in the US for customer service and has been for many years.
We did decide to try Comcast and see and we never even were able to get an installer out to run the cable from the streetside junction box. We were lied to repeatedly about just about everything. Made an install appointment and got time and date plus appointment CR number to identify it. It never showed in our account so I called the morning of the appointment and they said I never made the reservation. I told them I had a screen print of the chat stream that showed it and they said customers are not allowed to print anything that is in the chats. Then they magically found the appointment and said it would be on time that day. Nobody showed up, nobody called, and when called them the said I never made or confirmed the appointment. Just like the thousands of other problems listed on many websites about them. Cancelled everything with them and decided to get a now available ATT cellular data only plan. They allow all of the data to be hotspotted and you get 100gig for $90 per month which is about what we were paying for the DSL and landline with velocity. We now have Consumer Cellular phone plans that also have shared 50gig of hotspotting and the 150gig total should be plenty for us even at home and we can take the Nighthawk M1 4g lte hotspot router with us when traveling and have it all there also. The CC plan that is on the same ATT towers runs 4G lte hotspotting at about 32 MEPs and is plenty fast for our use.
The question would be what a good portable MIMO antenna would be that we could use at home and on the road to boost quality and signal strength in hard to get coverage areas. The Nighthawk will accept a MIMO 2X2 on T9 connections. It wouldn't be needed in good connection areas as the hotspot should receive signal OK just like the phones do (pixel 4a and pixel 6).
A possible right now based on not much anything as I know nothing about this kind of stuff would be the Waveform flat panel omnidirectional one that appears to be under 2 pounds so should be able to get a magnet to support it Ok, I hope. It is listed as compatible with Nighthawk M1.
Any and all ideas, recommendations, suggestions, explanations would be greatly appreciated.
