Must Tanks Be Empty to Replace a 2011 Roadtrek 210 Versatile Macerator?
Original Member Title: Do tanks need to be empty to replace macerator pump on 2011 Chevy Roadtrek 210 Versatile?
An RVer with a 2011 Roadtrek 210 Versatile asked whether closed gate valves would prevent wastewater spilling during macerator replacement, or whether both tanks needed pumping out first; the mechanic had also broken a valve handle. A member who replaced the macerator on a 210P said the gray and black valves should isolate the tanks, but theirs leaked, so they flushed the tanks as much as possible and used a catch basin, gloves and protective eyewear during removal.
Another member asked...
teslasmuse
Apr 5, 2026
84
Montana
My rv mechanic is worried he will get covered in urine and grey water when he removes the bad pump, but won't the gate valves stop that? I took it to a portable toilet place and they want 30 bucks to empty the 10 gallon black water through the toilet hole but their hose is 2 inches so he was going to try to brainstorm figuring out a smaller hose to get into the grey water through one of the sinks or the shower, but are we over thinking this? He also accidentally broke off this other gate valve handle claiming it's seized, but I'm not sure what the lower handle opens.
IMO overthinking the tank drainage.
I just changed out the macerator on our 210P. Theoretically the gray/black water valves "should" stop any flow but in my case they didn't. Next maintenance will include valve replacement.
You have 2 gate valve handles, one for sinks (gray), one for toilet (black). They both open the valves at the Valterra union that outlets to the macerator.
Suggest replacing the rubber 1.5" cooling that attaches the macerator to the union at the same time. Usually comes with new SS clamps and it's not expensive.
I carefully used a heat gun on the macerator outlet 1" hose to remove it, not a big deal. But stay clear and have a basin, "stuff" will come out. Not the end of the world. I did flush out tanks as much as possible before removing the macerator, but the valves weren't sealing 100%, thus the catch basin. Plus protective eyewear, gloves and a garden hose handy.
Side note, I have a 1" elbow with a clear section that I connect to the end of the macerator hose to so I can monitor black and gray water flow. Better for the pump to not run it dry.
I also added a fresh ground point for the new pump as well as a connector for the power feed. Be sure any connectors are rated for 25 amps. Avoids cutting wires next time (if there is a next time 😄).
I think my valves probably don't close and seal properly, either, so I was thinking about getting an aquarium transfer pump to empty the tanks since there aren't any solids and try to get them as empty as possible, the aquarium hose should be small enough to snake down one of the sinks or shower, will report back in a few days
Our 2019 has a connection for a standard 4 inch hose and a third gate valve, nothing like that on yours to gravity drain the tanks?
possibly, I'm taking it to the dealership Tuesday and hopefully they have better news and luck
I'm doubting it for your year model if it uses a Valterra T83H waste valve assembly. It's set up for cable control of the valves. It has 2 opposing inlets for gray/black water and 2 opposing outlets, one which is capped and the other connected to the macerator via a reducer from 3 in to 1.5 inch. Yes, the macerator is 1 in but the inlet also accommodates 1.5 in.
In my case I removed the capped outlet, can't remember it's either 1.5 or 2 in size and added an emergency drain with ball valve. Not ideal but better than nothing. The white pvc was painted black, not noticeable under there.
Welp, $1000 later for the pump ($375) and the diagnosis and 2 hours labor. The RV dealership replaced the macerator pump with the tanks full and apparently nothing really came out because they showed full and I was able to empty them with the new pump. I don't know how much I could have saved with the first shop, but I'm frustrated they refused to install the pump they ordered because the tanks were full. Now I know that when it intermittently cuts out it's probably close to failing so I will get it done sooner and save myself the stress. If you're blessed to have the space and knowledge to do a lot of this stuff yourself, I am jealous.
