Need advice on speaker locations.
05pleasureway 04chevy express 3500. no on star.
What location are you installing speakers. I prefer the pass. Side seat be turned backwards. (When there’s a passenger she sits on the sleeper sofa)Doing this covers the audio from the pass. Side front.
The driver side could be installed low in door where the oem speakers are but not a desirable location.
Here’s locations I’m considering.
also some ppl say grinding the ledge inside radio cavitiy isn't required oem radio is 6.25" deep the AVIC is just over 8" apparently I'll need to grind off almost 2".
Here’s the 2.1 sys. componets
2009 Pioneer AVIC-Z110BT
JBL 6.5 componets 3 ohm sound excellent no amp required w/ excellent effiency.
Pioneer 8” 2ohm sub 250watts RMS inside 2000 chevy Tahoe enclosure I think it’s ½ cubic foot.
Rockford Fosgate Sub amp. Mounted behind driver seat Rockford Fosgate R2-500X1 Prime 500-Watt Mono Amplifier turned
Not using wiring adaptor will run new 14 gauge speaker wire. Will use thicker antenna coax.
thanks for good advice
