Members provided detailed guidance on installing an auxiliary transmission cooler on a 2005 Chevy Express 3500, emphasizing the importance of routing and component identification. The consensus is to keep the radiator’s built-in cooler in the circuit for optimal temperature control, especially when towing, and to splice the external cooler into the return line from the lower radiator port. Several members clarified that the metal loop under the radiator is for power steering, not...
Members provided detailed guidance on installing an auxiliary transmission cooler on a 2005 Chevy Express 3500, emphasizing the importance of routing and component identification. The consensus is to keep the radiator’s built-in cooler in the circuit for optimal temperature control, especially when towing, and to splice the external cooler into the return line from the lower radiator port. Several members clarified that the metal loop under the radiator is for power steering, not transmission fluid. Visual aids and links to similar van upgrades were shared, and members stressed using high-quality plate-and-fin coolers, ideally with a fan for heavy towing.
Fluid and filter maintenance was a major subtopic. Members advised using genuine Dexron VI synthetic fluid for best compatibility and temperature resistance, cautioning against universal fluids. The correct filter fitment was discussed, with warnings that a loose filter or the wrong type (deep vs. shallow pan) can cause issues. The importance of checking fluid levels only when the transmission is fully warmed up and running was highlighted, as cold readings can be misleading. Members also recommended pulling the pan to inspect for debris and using a magnet to check for wear.
Key takeaways include: always confirm cooler line routing by tracing or referencing transmission-specific diagrams, avoid bypassing the radiator cooler, use manufacturer-recommended fluids and filters, and check fluid levels at operating temperature. For persistent uncertainty or hard-to-read dipsticks, a visit to a trusted mechanic is suggested for peace of mind.
