New couple
Sleeping Dog
Jul 8, 2021
Messages
54
NH
New Pleasureway Lexor FL. We'll be taking our maiden overnight trip to Acadia Nat'l Park this week.
The chassis for the Lexor is the Promaster and I'm wondering if anyone has experience with the Landed Gear spare tire mount for the rear door. Right or left door mount.
I'll also ask this question in the modification forum
84E2623B-E10F-4182-9952-16E12006F8C1_856d6070-5a26-41d1-bd6a-43ade9b12e5a_1024x1024@2x.jpg
Welcome to the forum!
Be careful mounting such weight to the rear doors. Most manufacturers advise against it, but that doesn't mean outfitters don't sell them.
I installed a Prime Design ladder to rear door on my 2013 Sprinter van for primary use of storing BBQ, chairs and 2 CuFt aluminum storage box. I estimate total load of about 75 lbs. I searched for manufacturers restriction but found none (http://www.sprinter-rv.com/wp-content/uploads/2010/09/Sprinter-Body-Equipment-Guidelines_2016.pdf), searched for rear door van storage failure before making this decision but found none.
Some tire mounts are mounted to frames bolted to hinges, so no load on doors, and some are mounted to door’s sheet metal. I would think if tire load on vans rear door is a real issue I would find something on internet, but I could be wrong.
I did found folks having difficulties with loading and unloading a spare tire from that height, it is heavy.
"Be careful mounting such weight to the rear doors. Most manufacturers advise against it, but that doesn't mean outfitters don't sell them."
That's why I'm asking around. Learn from others' experience.
Having been around manufacturers, they will advise against anything that they aren't selling themselves. It is protection for them against liability and responsibility.
IIRC correctly Ram advises against using their pickups for hauling truck campers. Given the number of grossly overweight TC that are seen on the roads, probably a good idea.
Yeah, manufacturers are quick to disavow many uses of their vehicles. My '2005 Honda CRV has the spare on the rear door. Hinges don't look as beefy as on the Promaster rear doors. But of course, it does not articulate past 90 degrees like on the new vans.
My rv spare is sturdily mounted on the rear hitch, but has to dropped down to access the rear driver-side door. Would be great if it just swung with the door.
Ask the outfitter how their product avoids stressing the doors. If you don't like their answer, you can always walk away.
Good luck.
Hello, I am new to this forum. I just purchase a 2019 Lexor FL and planning to do some cool mods to make space comparment and tire mount. When mounting to your back door you need to place a 1/2 to 3/4 inch plywood board behind the door to help support this weight. Door panel is not beefy enough to suport tire mount. Just cut the wood larger then tire mount (make sure you use decent bolts with lock nuts and long enough). I have not done this yet, I working on making under chassis storage bin. Good Luck
I removed mine. It's a personal preference, but IMO, unless you're off the beaten path, I would roll the dice. Less weight off the back end, more stealth looking, about a foot less in length, and something about jacking up 10,000 pounds and putting on an old tire, make me nervous. Blast away those who disagree. 09 Chevy Lexor TS
Check out "Landed Gear" brand spare tire mount. It's the go to one that the Travato crowd uses. No issues have been mentioned except they are sometimes hard to get because they can't keep up with sales.
Most install on the driver's side door because it gets opened less. And yes, they also have a license plate relocation mount available.
They also do installs, if wanted at their headquarters in So. California. And they have other accessories that they sell and install too
We rolled the dice once on being w/o a spare. Somewhere between Mandan, ND and no where, at dusk on a Saturday evening we ran over a broken off 1" diameter bolt that destroyed a tire. Fortunately we weren't far from a town. Unfortunately there were no tires available to fit that vehicle and it took till Tuesday for one to arrive.
If it is a simple puncture, I can plug the tire on the side of the road, pump it up and keep going, but not when it is shredded.
@MBecnel: Came across the Aluminess and that is an option, though it is twice as expensive as the Landed Gear.
@jakegw2: see my response to ChicagoTom
Wow, sorry to hear of your destroyed tire.
The same thing would probably happen to me if I ever removed my spare, so I keep it, even though I've not needed one in over 40 yrs.
Glad you were near a town and are back on the road.
Our adventure on the high plains happened about 25 years ago. We were returning from a 3 week trip to Glacier, Banff and Jasper and needed to be back to work on Monday, we lived in Mpls at the time. Beyond the additional expense for the tire and hotel/meals, we lost 3 days pay as we had used up our vacation. Like all travel disasters where no one gets hurt, it makes for good stories.
If I'm just puttering around the Northeast, I can survive with an aerosol tire repair and a compressor, but since the recommendation with those products is to repair/replace the tire within 100 miles, I'd rather plug the tire and continue on.
Given we have plans for traveling in the west again and it can be a long way between towns with services, I'd just as soon have a spare. Plus we intend on traveling to Newfoundland and across the Trans-Labrador Highway. While the Trans-Lab is mostly paved now, it still a lonely place with a long way between services.
Hitch mount spare
I would recommend a hitch mount, and you won't have to worry about the door supporting it. Also, REI (and others) sells a swing-away that fits in your hitch mount and has its own hitch mount. Install the swing-away in your hitch receiver, then the hitch mount tire carrier in the swing-away. That way you can open the door without removing the tire. When using this I always swing the tire away before retiring at night, so I can still use the back door as an emergency exit.
