Would you like to regenerate the title as well as the summary?
I poor some RV antifreeze down each drain (kitchen, bathroom, shower) to protect the traps. The excess antifreeze ends up in the waste tank so it helps there to protect the pipes at the drain valves.You can make a rubber or foam gasket to blow out the traps via the drain if you want to be super thorough, but it's not necessary.
I have never done this and my pump is fine. I just make sure it gets some air and then gets disconnected. Generally, any place where water can collect in small amounts and remain wont cause damage so long as there is air as well or an escape for expansion.You also need to run RV antifreeze (NOT automotive antifreeze) through your RV water pump. There are adapter kits available with a valve so you can run the antifreeze from the gallon jug. Takes about a quart or 2 to run through the pump to protect t it.
@GaryG-ClassB - I’ve been looking for threads on the blowout method you referenced but am coming up empty. Is there another search term? We hit minus thirty for a few weeks every winter so I want to make sure I do things right before my first winter with an RV. It’s parked in an open carport that keeps the snow off but offers no protection from the cold.
Pete
