New member with question
AK Vagabond
Apr 21, 2026
3
Various
Good day, new member here with a question regarding efficacy/need for backup 2000 W generator for use with a 2026 Gretsch strata ion. My question is does it make sense to use a small generator while Boondocking with the AC on if current draw is set to no more than 15 A, will power during use of the AC be primarily from the onboard inverter and preclude stalling of the smaller external generator? Or will the default be to pull first from the external generator/shore power?
I just looked at the literature for that model and it says you have a 17KwH battery system. Unless you do a lot of air conditioning and little driving you really don't need any generator for off grid use.
What is your planned use pattern including a guess at daily power use? That would tell us much better.
It is possible I’ll be off grid for several days and will be using the AC to keep cabin temps comfortable in the NM spring heat. With only 300 W of solar power, there doesn’t seem to be enough charging capacity to meet the demand of the AC. Although I haven’t tried this yet, I’m just trying to plan ahead. I’m also hesitant to periodically idle the motor to recharge the batteries. This seems like an inefficient and non-environmentally friendly way to keep the batteries charged. Not to mention that idling is probably not very good for the motor. I’ll be towing a small cargo trailer with a dirt bike so storage of the generator in the trailer would be pretty easy. Still curious and wanting to get my question answered about whether the coach will draw from shore power, I. E. Generator, or from the batteries through the inverter first? I’ve used an external generator before on a previous RV and the Honda 2000 is insufficient to power it. Will I have to shut down the AC and recharge the batteries using the generator, and only then after it is charged, use the AC?
Thank you as that is what we need to know.
If the AC runs much in terms of hours with compressor on, you will need to have a generator to last more than a couple of days. At 10 hours of compressor run a day you would use about half of your capacity.
The norm in class b vans and most other RVs, but I have no knowledge about it they have done the Gretch differently, is that shore power is always the first option for AC power if it is available, with a generator second, and battery power/inverter third. High quality inverters will have a power boost type feature that will supplement the other two if needed to carry the load, which with air conditioners can happen when the compressor is starting, but not usually when running or by running a microwave at the same time.
I assume you would be setting it up to plug into the shore power inlet plug on the van? If so, you should make sure that the generator you get is neutral to ground bonded to assure safety. If you plan on wiring directly into the van, the priority I stated will not happen correctly unless you add an automatic transfer switch as you should never have the generator and shore power connected to van at the same time. Using the inlet plug for the generator makes it impossible to have both connected at the same time so takes care of that.
2000 watts will probably run the AC OK unless you are using other power at the same time, like the microwave or inductive cooktop, so larger may be needed if you want to do that. If the van has the boosting type inverter, it will cover that, though.
Any way you look at it, the charging is likely to be much slower on generator or shore power to recharge a 17KW bank when compared to the van engine (driving) 51v alternator charging. Just compare that even if all 2000 watts from the generator went to batteries only it would 8 hours of running generator and using no other power to do it. Shore power is 3300 watts so would be faster than the generator but probably limited by the shore power. I can't say exactly how fast the van will charge them as we don't know if they limited the engine charging max output or not. If they are getting 300 amps of 51v power from the alternator that would be 15K watts which is a big load on the engine, especially if towing a trailer. 300 watts of solar is mostly for show in a 17Kwhr system, I think, as it will only give about 1.2kwhr per day in very good sun. Using the generator to keep up with power use as it happens, like with the air conditioner, is really the only practical way to do it.
I think one thing to remember is that it is very difficult to accurately answer questions when all the information is known ahead of time. In high powered systems like yours, you have plenty of power to cause all kinds of issues and those with those kinds of systems rarely ask about things like priority or running the AC unless they are using the AC a lot offgrid. In your case having shore power in the equation is not possible because you are are talking about offgrid use and that simplifies the question. If someone answers without all the information, I would take it as unreliable in most cases as it could be based on non long term AC use in their 2002 Roadtrek with one battery or such, or just a guess.
I completely agree with the not running the van to charge batteries as that, per Mercedes, is that you have to drive it for a stretch after far less idling than you will need.
Good luck with your Gretch, hopefully you can stick around or check back in to let us know how it all works out for you as more data on here is always helpful for others that might need it. I think that systems like yours will be getting more common going forward and I also think that some will be disappointed on how long even a huge bank can keep the AC running offgrid so a very good time to get this discussion.
Thx for thorough response! Need to get out there and establish camping pattern and actual power needs which will vary quite a bit I’m guessing. Appreciate the advice👍😊
Great plan, and varied amounts of power use is really the norm for most of us. Much less power on driving days or cool weather, etc can really make a difference
What you are looking for is the worst case times and how many days in a row you think they may happen over time. Once you know the power use during those times by experience it will get much easier to know how to address it. The air conditioner is the big unknown, I think, as will probably be the largest power user by a lot. What unit is will make a big difference as the efficiency of them can be a lot different and majorly change power use, and with AC units rated power doesn't accurately reflect actual real world use.
I just looked at the specs for the 3K Victron inverter/charger in the unit and it does have power assist for helping out a shortage of AC power by using the inverter.
The battery charging section at 55v charge voltage is about 1800 watts so with inefficiency, a 2K would use all or more of the generator output so nothing left for anything else. If you want AC and charging at the same time you will be using about 18 amps to charge batteries and the air conditioner is listed at 8-11 amps so you would be using all the 30 amp inlet power at the power plug right there and that is without any compressor starting load increases. Even shore power will be very limited beyond those two running if they even will at all as some shore power posts struggle to keep up sometimes. Perhaps Gretch is limiting the shore charger output to address that issue, but you would have to call them to find out. All of us live with the 30 amp power inlet limitations, but the big shore charger complicates it even more. I have our shore charger limited to charge at 40 amps of 12v only to address the issue as the only time we use shore power is to run air conditioning if necessary, but you won't have that option and the generator would also take forever to charge your huge bank. Your van could probably be better with a 220v shore power input so could do all the stuff you need to do.
