After more than a year of research, I could not justify the huge expense of a new Class B. We were able to find a 2003 Roadtrek 19 Popular and we are happy with our purchase so far. I decided that membership in this forum was what I needed. A few questions from a new owner:
The 2003 has a strange dump system. As I see it, after I dump the tanks, I have to hold the hose in the housing with one hand; lift the housing with the second hand; fold down the flap with the third hand; and then line up the the systems to insert the cotter pin with the fourth hand. I have to do all this while standing on my head and working in the dark. Has anyone found an easy way to reassemble the holding tank pieces? By the way, the Roadtrek instruction book advises that the support spring has to be wrapped around the flap to ensure that the hose does not come out. After frantically looking for the support spring, I found that mine did not come with one. I assume it was a later modification which did not get into the book.
The first time I brought the motor home in for inspection and repair, they damaged the area below the passenger door, probably by wedging a jack under the vehicle. Does anyone know where I can find the color code for the light blue portion of the paint?
Finally, I had considerable trouble trying to become a member in the first place. I could not read the verifying code required to register because I am color blind and have the beginnings of a cataract. The web page advises me to contact the Administrator if I am unable to read the code. However, there was no method to contact anyone. When I clicked on the contact Program Administrator, nothing happened. After a number of attempts, I got someone else to read the code and managed to get registered.
