cruising7388
LOL
Only 3-4 amps?
Do you believe that ???
:clap:
Yes, if the battery heaters are not on, he can believe that.
LOL
Only 3-4 amps?
:clap:
My bet is that any other loads full time are not included in that number, just the parasitic of the battery. Add on other electronics like monitors, inverter, etc and you probably have at least one more amp.
The tank and voltage monitors are LCD and are negligible loads and the bsattery disconnect relay is bi-stable.. The inverter is a different matter - when on and in no load standby it's drawing around 5 amps and Roadtrek recommends shutting it off when not using 120VAC appliances. Some of the anecdotes describing battery shut down when the vehicle is unattended are undoubtedly caused by forgetting to shut the inverter down when not in use. If I was designing this inverter, I would include a user programmable mode that would shut the inverter down after a non-demand period selected by the user.
The stuff all adds up surprisingly quickly. Even a gas frig unit will be in the .3-.4 amps range in most cases. Regardless of that, 5 amps for an inverter is inexcusable. You put in a huge Magnum or Outback and it will idle at maybe 1.5 amps, and they have a rest/monitor mode if you want to use, that will bring them to life if an AC load goes on. Roadtrek cheeses out with their off brand "proprietary" stuff, which is really just lower quality and featured than the price of the system would indicate.
............................ The wife and I have no RV experience but we are intent on purchasing an RV for near full time use and running an online business out of it while traveling....................
Have you considered other larger RV types if basically full timing?
As you would be going from no RV experience to near full time use I'll point out some of the advantages of a bigger unit: A larger rig permits a permanent bed, dry bathroom, dining area and work areas. You can get a unit with a washer & dryer instead of seeking out laundromats. There would be space for clothes hampers, trash bin & recycling bins. Food prep areas will be larger. It will have greater tank capacities etc. Two people would be able to move around with ease. There would be multiple closets inside for clothes and shoes. There would be lots of exterior storage for things like a larger BBQ grills, golf clubs, gear related to kayaking, biking, tools and/or other hobbies etc. There would be a choice of seating areas inside.
A car or truck would typically be the vehicle used for shopping, groceries, doctor & dentist visits & sightseeing. With a B van, everything thing needs to be packed up & stored to make the vehicle road ready for those frequent trips. The van would need to be parked level enough for your comfort so that might entail leveling it after returning from each those errand or recreational trips. There would be no certainty that your parking spot would still be available upon your return if boondocking.
Just thought I'd throw all that out there for you to consider.
To me, the below floor storage is a huge benefit, as they can use up half the inside with batteries and such. Since no generator, there is lots of room underneath. I would not put them inside, even if I had to get the underbody mount done by someone other that the installer. I hung 440ah of AGMs under our Chevy without a problem.
Booster, do you have any way to protect batteries from cold temps with them hung under the rig?
it amazes me the number of class b'ers who want a composting toilet.
the size of a class b makes it impractical to me.
Greetings all, and thanks for this forum and the wealth of information it supplies. The wife and I have no RV experience but we are intent on purchasing an RV for near full time use and running an online business out of it while traveling.
We are strongly considering pulling the trigger on an RS Adventurous XL with Warp Core if we can find one used or perhaps new for the right price.
You couldn't pay me $139,000 firm to own that.
The chance of finding a preowned Roadtrek with the warp core option is slim but there is one available at Advanced Research Vehicles. It's a CS model which I think ist he best Sprinter layout that Roadtrek builds. This coach is a fully loaded 4 x 4 XL version with 1600 ah lithiums, 600 watt solar, Voltstart, drop down rear cabinet, Alde heating. If you want the improved VB suspension, they can provide it. ARV's reputation is unparalleled and any representation they make you can take to the bank. The person to contact is Janice Spicuzza at ARV, 440-283-0405.
https://advanced-rv.com/pre-owned-class-b-rv-for-sale/
I see an opinion. What is your point?
I've read enough about Roadtrek and their lithiums and voltstart to figure that coach is probably being traded in for one that actually works.
