I envision things working as advertised, safely.
Dan Neeley lives in your neck of the woods. You could always call him.
What I am a supporter of is burn in and functional testing of high value, low production, complex, items that can cause problems or incur expensive downtime and repair if they don't work correctly at install or fail quickly.
We don't know the failure rate of the Ecotrek, Voltstart stuff, but I have to believe that the cost savings in field repairs would likely cover the costs of a full functional testing of the systems before leaving the factory....
It still baffles me how this seems to go on and and on, and repeats on new products.
It's not so simple. The optional second alternator MB brackets used for the Nations don't work for the Delco-Remy alternator. Advanced RV had to design and manufacture a costume bracket and pulley system among other things to accommodate the Delco..
Come to think of it, I would pull that Nations alternator and put a AC Delco in its place.
…………………………… I am not a supporter of "inspecting in" quality, as I know it rarely works and is hardly ever more than about 80% accurate…………………….
Not to worry. As you go onward and upward in life, the plaintive voices of the doomsayers become fainter and fainter in the distance.![]()
I wouldn't exactly say doomsayers, just realists in the fact that Roadtrek has had problems with the new systems in a lot of cases. Just saying there is not problem doesn't make problems not happen, either.
Every expectation has to be that they will get it fixed and ready to go, but it doesn't change the fact that the problems should never have happened in the first place, weren't found by the dealer, and are taking so long to fix.
Hello, new Roadtrek Agile owner. I've been reading these posts and experimenting with my two Ecotrek modules. What I found is that your assumptions about parasitic losses are correct, I get to about 50% battery from a fully charged Ecotrek module in a day if I don't use any loads but only if Ecotrek is turned on AND it's connected to the coach. If I use separate Battery Disconnect switch (works on all modules), then even with Ecotrek still turned on, I do not get any losses (same as when it's off). So there must be something in the way Ecotrek is connected to the coach that makes it loose power.
Note, you can still charge Ecotrek with Solar while it's ON but disconnected from the coach and it's much faster than when it's connected.
