Newbie from California with electrical issues
rhoda-ClassB
Nov 20, 2016
6
California
:D
Greetings all!
I just checked another bucket list item off and bought my first RV. Got a 1998 Roadtrek Versatile. Needs a little work, but I didn't pay much. I am soooo excited to get going. Trying to learn all I can.
I am generally good with mechanical things and fixing stuff but the electrical systems still baffle me no matter how much I read. Amps, watts, volts, all sounds like gibberish to me and I can't quite get a handle on how it all works.
Just like I don't have to know how to fix my car to drive it, I'd like to understand enough about the electrical system to use it safely and efficiently.
Can someone recommend a book, website,youtube, or someplace else that I can get some basic understanding of electrical stuff on my rv, that isn't too detailed and technical????
Thanks a ton. I've learned a lot already by reading the forums.
many of the forum members are using solar systems- which add a level of complexity.
unless you have solar- you don;t have to pay attention to them- same with more "modern" underhood generators.
you probably have a system similar to mine.
where the van motor alternator charges the "coach" batteries as you drive- when you stop, the 12 volt stuff in the back runs off of that battery- the lights, maybe your TV, water pump etc.
you may also have a generator under the van- this will supply 120 volt power ( like your house) and will power the outlets, air conditioner and microwave- and it will also re-charge the coach battery back up to 12 volts if it has been run down.
in a camp ground ( or driveway) you can plug into power and the 120 volt stuff above will work, and your battery will re-charge. ( "shore power")
this is basic over view.
ensure that your battery and cables are in good shape- you can have an autozone test you battery- I buy new batteries at costco
youtube will be helpful for learning your van- how to dump the tanks etc.
you may have a 3 way fridge- use AC when on shore power, DC when driving and propane when parked without shore power- even for short periods like stopping for shopping.
you may find that on an old vehicle that previous owners have modified the systems- these can be an improvement, but can add a level of complexity to repairs if they are not documented
Mike
