I did a complete an electrical makeover/upgrade of the house system.
We have a 2008 Chevy 2500, Roadtrek 170P. A RT 190 or 210 would provide much more room to perform this type of "makeover."
The effort is relatively easy if you plan the effort, can weld, have some wiring experience, and a patient understanding wife/spouse/partner. It may not be inexpensive, but rewarding. Depending how far you go, it can run close to $10k quickly. Its something you
can do incrementally:
- I removed a non functioning generator. Replaced with a welded frame for encased 520Ah of LiFePO4 batteries. Fitted in place of the generator.
- Removed and replaced the factory air conditioner with an inverter ac unit. [but you said...]
- Removed all the "stock" inverter/charger/shore power components and upgraded to a 3000Watt inverter/charger. [This also supports the microwave.]
- Upgraded to a high capacity Battery to Battery charger/controller
- Upgraded the alternator from stock to 420A hot-rated
- Improved the measurement and control of the system
- Upgraded "miles" of cables and dozens of fuses and connectors
- Added a few tools along the way, and we are happy campers!
You said not to include the air conditioner. What about microwave? These both require sizable inverters and battery capacity.
My mantra:
Identify and Understand your Consumption
Right Size the Capacity - Understand and build to Depth of Charge
Provide the necessary Charging resources
Cheers Jim
Many images on my "albums" page. I can share a spreadsheet (PM me) of the costs, but certainly some prices have changed.
