Here is the wiring diagram. As was mentioned earlier Roadtrek uses auto reset breakers in the wiring from the shore charge to separator so you won't find any fuses. The will be small metal mostly square cans that likely have 4 connections on them because they use two 40 amp breakers in parallel. You will have 3 of them in the cable from the charger to the separator that are 15 years old, and they fail fairly often. The norm on other Roadtreks would have one near the Tripplite, one underneath the van and another by the separator. Probable at least one will be under the van in the elements. You need to track the entire cable to find them I think.
The are the blue squares that are labeled 80 amp breaker in the wiring diagram so it they built it per the diagram there will be 3 of them.
