CONFIGURATION
ONAN 2500 Watt GenSet – LP fuel - Microlite 2800 Series
Model 2.5KV FA26120K, S/N: K030571650
Motorhome: 2004 Leisure Travel, 210 B, 2003 Mercedes Sprinter, 250k miles
20-year-old generator has 300 hours on it. Mounted below.
I’ve owned, operated, and maintained it for 15 years. Routinely Exercised. Oil, sparkplug, filter, good.
ISSUE
Will not start. Attempts to start are the same using either the remote Start switch or the one on the generator. Start button results are no crank or clicking. This has been an intermittent issue for the last two years. When it does start it runs fine. I tried to relate it to level issues, time, weather, motion, periods of use or idle and never found any correlation. On a recent trip it started and worked well several times, then failed to start. Two weeks have now passed and repeated attempts to start result with no cranking.
Mounted under the Sprinter makes it very difficult to analyze. Dropping it out is way beyond my ability. All the 12-v systems in the motorhome are working and in good condition. All the underside cabling to the generator looks clean and good. I’ve tried to determine if 12v DC is getting to the generator. The 12-v cable is housed in a conduit so I can’t get a probe to it to test for voltage. The 12-v supply cable originates in the motorhome where I can access it. That connection is clean, solid and a test probe into the cable shows good 12 v supply voltage. The 5-amp fuse in the generator was good but I replaced it with a new one to make sure it is good. I made a test connection into the 5-amp fuse holder and did not see 12-v there. (12v references includes tests at actual 13.5 v.)
Twice I measured for voltage on the remote switch start wire and found it at 11.5v. As soon as I pressed Start (no crank) and released the voltage went to 0 v. It appears that there is some weak component in the start circuit path that produced this.
WHAT NOW?
My coach battery is a 100AH AGM that serves me well. We most often travel part of the day, so the engine alternator usually recharges us, and I have some solar. I have considered converting to lithium but do not want to do that. As indicated by the 300 hours on the generator, not much use in 20 years. I could live without the generator, but I like to keep this motorhome healthy.
I prefer DIY if not to fix at least to diagnose it. I haven’t been able to do either with this issue. It looks like I will have to take it in for service, Cummins/Onan most likely. If I do take it in, the labor cost to drop and analyze it will be considerable even if the repair is simple. And then what would its future be? I am considering replacing the KV with the new Onan QG 2500i LP. I know it’s a huge cost but would be reliable for years to come, I assume.
So, what to do? I am looking for insight into the issue and guidance on how to proceed. The resources on this forum are amazing and I will be grateful for your assistance.
Thanks,
Pat, Minneapolis, MN
ISSUE
WHAT NOW?
Thanks,
