Horseshoecat
Finished installing a new 6,000 BTU air conditioner in our Roadtrek Versatile 200. It works perfectly connected to shore power.
The generator....that is another story. The A/C will start okay and then just blows warm air. I had the A/C running fine, turned the "cooling" off, with only the fan running; hit "cool" again and nothing but warm air. The compressor will not kick in
So I read about soft and hard start kits....and those are available for the built-in type A/C, but nothing for the window-style A/C used in the Roadtrek.
OR, can I plug the A/C into an inverter with the generator running?
Can someone please point me in the right direction to ensure the A/C will work with our generator.
Thank you so much.
HorseshoeCat
Thank you so much.
HorseshoeCat
