Ron J. Moore
For a little over two months my RT sat idle; I couldn't get out to do the required exercise....you know the rest of the story!! I've run it down to just over a quarter tank and added a can of SeaFoam - will fire but not keep running. Today I finally got under it and removed the cover, air filter and sprayed Deep Creep (Sea Foam in a spray) into the opening - nah!! It would run a few seconds longer, but not there yet. I checked the choke and it is open (after sitting all night). If I hold the choke assembly it will run rapidly but then will die out.
Anybody have a suggestion on how to correct this sticking choke problem? I thought for sure the Deep Creep would loosen up any hang-ups. Thanks, Ron.
