Greetings all.
I thought I would post a little about my experience trouble shooting a PD720Q progressive dynamics converter and how I ended up having to trouble shoot something that was working fine before a fire and I had to take my RV in to get fixed.
A couple years ago I had a fire from an overfilled propane tank and it seems I am still working out the aftermath of getting work done at a "professional" shop.
The Gas station did end up paying but meanwhile I had to go through a "professional" top get it done in case it had to go through insurance.
I thought I was done fixing the "professional" install last year and was trying to figure out why the converter stopped working last year.
I downloaded all the manuals and links that Markopolo provided and started to get to work on it. Progressive Dynamics steered me to a fella called Wes Miller at Mastertech and he gave me a couple pointers on looking a little deeper when I was about to give up and buy a new converter. It was old and had quite a hum when I was using it. After talking with Wes I decided to stay on track trying to fix it instead of giving up and replacing it. It did not take long to know some of the hard things to replace were not the problem by using some common sense and the links that Markopolo provided.
You can find all those links on the Thread RE: Total Electrical Upgrade by Markopolo
When I plugged into shore power it would click ( relay to go from battery to converter for 12V) and anything on 12 volts would turn off and it would not charge. As soon as I would unplug the converter from shore the 12 volt from the battery would come back and everything worked.
I went through the unit testing continuity and power and everything "seemed" fine with the SRC, diodes and breaker and I was getting 12V out of the converter but it was not making it to the 12 volts system feed. I checked all the fuses and breakers and everything was good. Once I figured out that the Diodes and transformer seemed to be working I thought it was the charge board problem ( 6 wire ) but thought I would check the ground although there was no reason it would be bad but when I jumpered the ground everything worked instantly.
It was a simple open ground!
When I had the "professionals" to it they messed up so much stuff It got to the point it was easier to redo it myself instead of loosing time trying ways to leave my RV there repeatedly , they also made excuses for a bad install and never read the install manual. I figured out this year the converter never worked because they did not connect the ground properly. They used a butt connector and it was not crimped on the actual wire. they also used 1o gauge wire to bridge the burnt up 8 guage wire and the crimps were weak and pulled right out. While a owner could hack a 16" length of under gauge wire in I feel it was unacceptable for a shop to do it and the terrible job they did of it. If they would have tested everything as they should have this would not have happened.
I took out the work they did and replaced both substandard wires and soldered in a 8 gauge wire for ground (-) to battery and the power wire to battery and now everything works as it should.
I am seriously thinking about completely replacing most of the 12V wiring from point to point as well as the 110V they also made a mess of. I know that will not get done this year for sure.
You can't do everything yourself all the time and and sooner or later you have to trust someone, and all you can do is cross your fingers and pray.
