Propane Solenoid failed ?
@Michael
Oct 26, 2018
531
MN
I have a Coachmen Crossfit with what seems like a failed propane solenoid. There is power to the solenoid, but I don't hear the thunk that it normally makes, and of course have no propane at the appliances.
The valve looks like a model V20533.1p like this :
https://store.nashfuel.com/products/v20533-1p
Does anyone know if I can replace the solenoid without replacing the whole valve?
I recently replaced the solenoid on my 1999 RT 170. It is a different style than yours (see the pic below), but it was all just one unit. I am not sure on your style of solenoid, but I would be surprised if any part of it could be removed and replaced independently because I would think that the parts function interconnectedly. But mine was 1/4 of the price of yours, so I can see why you would want to try if it is possible!
Smack it with a hammer on a screw driver. Worked for me. The oder agent they put in propane can collect and gum it up.
As for replacing the solenoid I would guess no.
A cheaper alternative to the solenoid - but with a long lead time.
https://americancng.com/products/rotarex-lpg-solenoid-replacement-a1572
I bought two to keep one on hand.
You can test the 12 volt power to the solenoid first though to make sure you do not have a bad switch. When on the solenoid is warm/hot to the touch.
The solenoid it self can be tested with a meter for resistance, you can google it.
Finally you could use this strong magnet to test or temporarily hold open the valve:
https://www.amazon.com/gp/product/B01N8S12GM/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Thanks for the links.
I checked the solenoid - it's not passing any current, so likely dead. I can't tell if the valve is stuck or not. Tapping on it didn't make any difference.
I'll try the magnet trick, and order a solenoid. I found one in stock at Nash Propane, but its 4x the price.
https://store.nashfuel.com/products...v20533-1-144251-01-702?variant=42789434753181
--Mike
Contrary to my previous post if the solenoid can be removed (snap ring) it can be replaced. The solenoid isn’t sold alone so it doesn’t make much difference.
And now I see it is sold alone. My older RV uses a manual valve. Inconvenient sometimes but it does have it’s advantages. No current draw for off grid camping being the main one.
I ordered that magnet, which was able to pull the valve open. So the valve is not stuck. The solenoid is toast. The good news is that I can use the magnet until I can find a replacement solenoid.
Thanks for the tip. :thumbup:
Glad to hear that you have a workaround until the new solenoid comes in.:cool:
