Replacement Inverter/Charger for Roadtrek Ecotrek
Moto vita
Jul 10, 2023
23
Washington
The Inverter/Charger unit in my 2017 CS Adventurous has finally died so I'm looking for a replacement. Anyone who has a van like this, standard length with 2 Ecotrek 200s, knows how tightly it fits alongside the couch frame and the heavy DC wires allow almost no movement, so the replacement needs to match dimensionally as closely as possible. I see this one that looks to be a twin to the original Microgreen, which is no longer available. https://www.amazon.com/Redodo-Inver...tteries/dp/B0CT2QRM3S?ref_=ast_bl_cpl_dp&th=1
I still have the old H series Ecotrek batteries, I'm sure they've lost some capacity but they are adequate for my use. Nevertheless I expect them to fail before too long.
Does anybody here have any applicable experience, opinions, or other suggestions?
Nothing magical about the original inverter/charger. Primary issue, as you note, is that if placed in the same location there is not much latitude for different dimensions. I do note that the charger output on the one you linked is only 45a, the original is 100a (at least on my 2017 RS Adventurous). If you have the outback option as I do, keep in mind that the galley inverter is identical to the house inverter, and you can swap that over and use the unit that you linked, given that the gally inverter / charger is not used for charging the systems.
I spent some time planning for the inevitable changeout of the etrek 200's (I have 2) on my RS. There are companies that specialize in making new modules with more modern battery, including upsize of the modules to 300ah each. Comes at a price, but a solid option. One of a few examples I have found Roadtrek & Hymer KS2 Ecotrek Battery Replacement - EDGE Vanworks . I will be going a different route, but you need to have a solid understanding of the existing system before you start modifying.
My system only has one inverter, I think that's because I have a propane cooktop. I haven't heard the term "outback option" before, what all is in that option? I'm specifically trying to avoid making modifications.
Outback option included, among other things, fully electric kitchen (induction stove / convection oven/micro, 400 something watts of solar, under hood generator, Alde system heating and a few other things - basically a fully electric unit with diesel fired hydronic heating and hot water (simplified description). The 2017 build sheet called this out as a $20k option package - I am the 2nd owner but have all the original paperwork. If you want to avoid modifications of any sort, you need to get replacement etrek modules (or get then rebuilt in kind). If you want everything to operate better than original, go with one of the builders who can modify / upsize the ecotreks modules to 300ah each for less than the factory new module cost.
I will be eliminating all the "junk" in the ecotrek modules (external BMS, heaters and contactors) and installing modern batteries with BMS and integral heating. Requires more than simply that change , but I the result will be a more modern / reliable system. This is also probably the lest expensive option - but I emphasize, you have to understand what is there before proceeding. I spent a good deal of time diagramming the coach side of the unit to make sure I was right, and only have a few things (primarily under the drivers seat around the DC isolation contactor/relay) to confirm before I am fully prepared for replacing these when they fail. I also plan on adding additional capacity under the passenger front seat, since my ALDE system does not have the diesel motor / ALDE heat exchanger and pump installed and that space is currently unused. There is mercedes factory option for an aux battery tray under that seat, if you want some hints on what I am thinking Playing with whether to use additional AGM capacity parallel to the AGM under the hood for the etrek system, or additional LIFEPO. Both have advantages.
My van is equipped the same except for propane Alde and cooktop, I am the original owner. Realisticly I probably don't have more than a couple more years that I'll be able to use the van, I'm hoping the Ecotreks can hold out that long. I really don't need more capacity, I typically move the van every day when I'm using it so the batteries get fully charged daily.
I checked my inverter today the charging output on my 2017 Adventurous is 50 amps, I suppose your 100 amp charger may be part of your "outback" option.
