Replacment window 1999 roadtrek 190
Kryssstorm
Oct 11, 2020
Messages
4
Az
Half my rear side window fell off and its getting cold where can i find replacement parts, or are there rv junk yards
Hopefully, you still have the bottom half of the hinge that was attached to the window.
As far as I know, individual parts are not available.
You can go to a glass company and have them cut a new piece. Use the other window and trace it to make a template. If you have a piece of glass made, bring it to an auto glass company and have them glue the hinge on. they use a primer on the glass and a windshield adhesive. I had mine done this way. You can also consider Lexan instead of glass.
Do a search on this board about replacing the rear window glass. Lots of good posts and suggestions.
Ok so i talked to a glass manufactur and the window has a curve they can't or won't replecate. Called around still no luck
replacement window kits
Ask your question on this Facebook Group https://www.facebook.com/groups/148366135690824/?__cft__[0]=AZWePXEi11gCUueatUiB5_J_HvhGFv0aL4LnDYSeGgHjPe2zv00AYSuL_NgsbKP0ItOBBURhn_bBDOThrPNY9JFvTzcyGlgtSDQaXA9Vopj28A3jPy7zlNJ0bYJSmu1hMqAFKbZZOjd5obygA7IjpknMdJHunVm_O3pQ2yr-cadHIGHNLD_8PVyRv4UJHsnYbTuKJGRTuFsn7URz4hIrF_iUZV52MCOGko5kvvp8Z8FOsg&__tn__=-UC%2CP-R
Jack Wood'74-'04 Roadtrek Owners - Vintage & Classic years
Feb 25 · '74-'04 Roadtrek...
· …new batch of CR Laurence frameless window replacement ready to be shipped out! Made out of highly durable and impact resistant 1/4" acrylic plexiglass. Up to 40 times more impact resistant than the stock CRL window. These windows are made so they won't fall off and you
Roadtrek replacement windows
I also recommend that you search for Jack Wood on the Facebook group called '74-'04 Roadtrek Owners - Vintage & classic years. He not only makes replacement windows, but has a better mounting system.
Replacement rear side window option
The lower section of fold out CR Lawrence rear side windows fall out over time.
Consider cutting a piece of tinted Plexi Glass to size and connecting it to the remaing upper window with black Endura tape or Flex Seal tape.
If a neat job is done it looks surprisingly normal and I was able to rig the crank out fuction to work.
This allowed us to complere our cross country travels and have Sunshine Sate RVs in Gainesville Florida to install a permanent replacement (not CL Lawerence) by cutting a bit of sheet metal away. Sunshine State RVs knows Roadtreks -
BJ - 3rd Roadtrek - out touring
Not sure if you solved your problem yet, but I was able to purchase the opening read side window from Van Life last August but it came in too late and I was already on the road heading to Vancouver Island. Things got busy and too cold so I will be looking at getting it installed soon.
