Rialta Inverter Battery Wiring
Quickmagic
May 2, 2024
3
I have a 2003 Rialta where the inverter has been replaced. It’s wiring, ( + and - cables) running directly into coach battery box. Question; should the + cable be wired directly to the battery, or should it be wired to the solenoid, and if so, which post on the solenoid?
Thank you!
The inverter positive should go directly to the coach battery positive with the proper fuse or breaker close to the battery. Negative to the coach battery negative or ground bus. I would not use the solenoid unless the Rialta wiring diagram specifically calls for it.
