Venting is very important. Could the top vent be blocked?
Here's some info from Dometic:
Refrigerator Does Not Cool Properly
A. Burner jet clogged. Clean. (See section Maintenance & Service, Item 3. Periodic Maintenance, Paragraph D. Item 1-14).
B. Check level of refrigerator.
C. Venting problem.
D. Heavy frost buildup on evaporator fins. Defrost
E. Flue baffle not inserted properly in flue tube.
F. Improperly set thermostat. (See Operating Instructions, part Thermostat).
G. Burner dirty. Clean. (See section Maintenance & Service, Item 3. Periodic Maintenance, Paragraph D. Item 1-14).
H. LP gas pressure low at burner. Set main regulator so pressure does not drop below 11 inches of water column at pressure tap.
I. Burner not located properly under flue tube. Relocate
J. Burner damaged. Replace.
and some info from Roadtrek:
[quote:3vdpw7fk]Tips & Tricks
From Roadtrek®TM Owners
Tip #1 - Refrigerator Use & Maintenance
As the refrigerator is the most used and relied upon appliance in the motorhome, regular service & maintenance is very important.
The refrigerator operates by heat applied to the boiler system and it is of paramount importance that this heat be kept within the necessary limits and be properly applied. Keeping the unit properly cleaned and tuned will ensure that the heat exchange is kept within the required limits. This heat exchange applies to all three operating modes.Although regular service & maintenance will vary depending upon usage, yearly service is recommended by the manufacturer. This service & maintenance should be performed by a certified Dometic Manual Refrigeration Technician.
Here are some suggestions to keep your refrigerator up and running between scheduled service.
Be sure to check the burner flame for proper appearance. The flame should be light blue. If it has a yellow tip, this means it is burning incorrectly and should be serviced. Check to be sure there is no spider web, insect nest, soot or rust on or around the burner. If there is, knock it off with a small screwdriver and clean the area with compressed air or by blowing through a soda straw.
For proper ventilation, keep the area behind your refrigerator clear. Check the upper and lower vents and the area between vent openings for any obstructions such as a bee or birds nest.
Check all connections in the LP gas system (at the back of your refrigerator) for gas leaks by applying a non corrosive commercial leak detector solution at all connections.
A properly serviced and maintained refrigerator should provide years of trouble free service. To receive a brochure on maintaining the Dometic RM2310 manual refrigerator, call the Communication Center of Dometic Corporation at 219-294-2511.
