OK, I apologize for the delay. Here is some pictures of how I installed my cooler underneath the van. You can see it is at a downward angle. It has a in-line thermostat switch that kicks it on when it hits 180 degrees and shuts it off at 160 degrees I also installed a Transmission temp gauge. I know it’s not an instant read but it gives me a good idea of what the van is doing again. The hot fluid goes to the transmission cooler in the radiator, then comes out and then I spliced in the return line and sent that to the aftermarket coolerp that I installed and then back to the Transmission. We’re going to Glacier and Yellowstone in a month so I will pull it out and maybe get some better pictures if I remember and tidy the wires up now that I know that it works excellent.
I used Hydraulic hose because I don’t think too much of the hose they sent with the kit, but I also make hydraulic hoses so I can do that easily. The location of the cooler is pretty much behind the driver seat next to the driveshaft behind the transmission, I was laying on the ground on the driver side, taking pictures. That’s why I took the one of the side of the van for a location reference. You can see the front tank drain in the one picture.
