This Sunday will end a month-long road trip, much of it through mountainous regions. I'm happy to say that our tubby has functioned well both up and down grades, and thanks to youngnretired for a timely post:
www.classbforum.com
The van has hit 100k miles now and aside from the regular maintenance I'll do back home, I'm considering doing some PM to the 2-piece driveshaft. It's in good shape, no weird noise or vibration. However the center carrier is getting a bit tired (rubber ring still intact), and I'd rather go ahead and replace the 3 u-joints and carrier in the convenience of my shop at home.
Another factor is that the front two u-joints have the factory plastic injection retention vs snaprings. I'd much rather heat and clean that out at home vs on the road somewhere.
I'll use a GM oem center carrier, but I've always had good luck with Spicer u-joints, specifically the SPL series. I've found them to be high quality, precision fit, and with features such as thrust washers inside the center caps, and high yield ratings. I'm on the fence about lube vs non-lube u-joints with the consideration that the non-lube versions are slightly stronger due to no additional holes drilled.
I realize that there's a if-its-not-broke consideration, but the problem with u-joints is that when they fatigue, they break , usually suddenly. If you're lucky the driveshaft isn't destroying itself smacking the road. Thinking back on the high torque applied going up grades, I'd rather be safe than sorry. I'm aware of keeping the factory driveshaft phasing intact, etc. and I have the equipment to safely remove/install carrier. So its my "free" labor and cost of parts.
Interested in any input, recommendations, etc.
Tips for descending a steep grade
I've tried to google ideas for descending a steep grade in a heavy van, but all I find is things on semi's with jake brakes. Not quite applicable to our 9200lb 08C210P Roadtrek. Since I live where it's pretty flat and we'll be traversing some grades on our trip coming up, I'm just inquiring...
