Michelin. I just put on four new last week. I had the Bridgestone’s that came with it when I bought new…..the Michelin ride much better.
Last year I went with the michelin agilis cross climate
happy with them
Mike
I own a 2017 RoadTrek Popular 210 built on a Chey 3500 chassis.
While the Michelin LTX M/S seem to provide a better ride. We found a BIG Problem with them.
The Michelin were the EXACT size as the original Bridgestone, BUT they are VERY Different. The difference is the way they are made.
THEY are bigger and wider which causes them to RUB on the back inside of the wheel well against the truck frame when the wheel is turned. The rear tires also rub against the back of the wheel well plastic.
We had to change the tires back and what a difference in the room. I did not want the tire to blow unexpectedly.
I never ran into that situation before, but was told by a truck Mechanic that it happens a lot.
Wow! great catch. You saved me a fortune. Wonder if this is only Roadtreks or would chevy express have the same issue.
Thanks
Michelin Defenders have always been good on my Chevy Roadtrek 210
As far as the Off Roading in 210 Roadtrek there are several issues, 1. The chassis is already heavily loaded with all the household fixtures 2. Clearances are close. 3.Exposed tanks, drain pipes and generator are going to take a beating. 4. High centering a 22.5 foot long vehicle is easy to do. I have scraped bottom crossing some railroad crossings.
I'd suggest towing a jeep for your off roading
How new are your shocks ? I have a 2017 Roadtrek Popular 210 and it had almost 50,000 miles on it and the shocks were shot. We put monroe extra heavy duty shocks on and the handling went way up.I have a 2003 Pleasure way on Ford 350 chassis, I am on my 2nd set of tires. My problem is handling going down the road wondering. My 2nd set is Copper's, would the Michelins help with that. If I have read right they have a stiffer sidewall. Any opinions on this.
They were the same size as the original Bridgestone.Do you recall the tire size for the Michelin?
I don"t know, they look new but that doesn't mean they are. Thanks maybe try new ones and change to the Michelin tires too. I also have airbags that I carry 50 psi in.How new are your shocks? I have a 2017 Roadtrek Popular 210 and it had almost 50,000 miles on it and the shocks were shot. We put Monroe extra heavy-duty shocks on and the handling went way up.
