I'd like to replace the 700w inverter in my 2004 Roadtrek with a 2000w so as to be able to run my microwave. I reached out to Roadtrek and they said I should get a professional to do this since the wiring might need to be upgraded among other reasons. Does anyone know if my swapping out the inverter would necessarily require new wiring?[
I have a 2010 Roadtrek Popular and am someone who uses a microwave a lot. I plan on upgrading to 200 amps of lithium ion batteries anyway, and have thought of simply wiring in a second, higher capacity inverter and running power to a 110 fused disconnect near the microwave and a new 110 outlet. Power transfer would be easy-- plug into the inverter for battery power, plug into the original outlet for shore power. One circuit for the inverter. The new accessory inverter would simply be a new draw on the battery and not need changing any of the factory original circuitry in the van panel.
Weigh in on the technical feasibility of this, please. It isn't that much money or time involved to me, it's a functionality that would bring a lot of enjoyment to me.
Additionally, I boondock and stealth camp extensively, so firing up the generator just to make some ramen simply isn't that practical or desirable.
You don't say if it is a 170, 190 or 210, but all are probably similar in wiring but not necessarily in where the parts are located in the van.
The microwave is not on the current inverter circuitry and probably has it's own 110v breaker in the breaker box by the entry door. There are really only two places to access that wiring, one at the microwave and at the breaker box.
The outlet for the microwave on our 07 190P is behind the microwave so not accessible to swap plug ins without removing the microwave. So that will be an issue for you if yours is similar.
There is also the difficulty in running BIG 12v cables up to wherever you put the inverter by the microwave if you do it that way. If you run a new AC line to the area from wherever the inverter is going to mount, it might be easier, but you would need the 12v cables to that area.
A lot may depend on where you put the lithium batteries and where the existing charging parts are located. On a 190 the charging parts would be behind a panel at the passenger side rear behind the wheelwell inside the van. Batteries would be in the passenger side outside storage bin in front of the year wheel and accessed from outside.
If you don't have it, get the owner's manual from the Roadtrek site, and if it is the new version manual without wiring diagrams and locations get one from about 2008 as they have the diagrams and locations. They should be very close to correct for a 2010.
The first time we modified our 07 190 to run the microwave on an inverter, I also changed the charger and got rid of the Tripplite that was in van originally. I put a standalone charger and separate inverter in the same area as the original Tripplite. Using and inverter/charger with an internal automatic transfer switch would be easier. To get the power to the microwave I just moved the wiring for the microwave outlet to connect to the kitchen outlet that is on the inverter circuit from the factory.
Best, I think, is to get a more detailed plan based on the model you have, where the lithium is going sit, and where all the other bits and pieces will go. Pulling wires, especially big ones is not easy in these vans so avoiding that need will simplify things a lot, IMO. Especially if you are going to change to lithium also, you need to consider the entire system and how it all has to work together. No matter what the sellers say, lithium is not a simple "drop in" replacement for lead acid batteries, IMO.
Most 2K watt pure sine wave (needed) inverters will has significant idle power use, with somewhat less if they have a "search" feature that might work in your case. Being able to turn it off would be good thing to have with only 200 AMP HOURS of battery capacity.
It is likely that your system, if it is AGM or wet cells and a Tripplite, will have only 80 amps of power to the coach from the alternator. Ours had a 4ga cable and 80 amp breakers for wiring. Even two AGMS can pull more than 80 amps when charging and cycle the breakers repeatedly. 200 amp hours of lithium will take way more the 80 amps and trip them all the time while trying to charge while driving. A battery to battery charger or other current limiting device will be needed to go to lithium if you are going to charge off the engine.
Stealth camping in a Roadtrek seems like it would be pretty tough as they are very obviously an RV.
