I had noticed some time ago that the door on the cabinet next to the microwave doesn’t latch and appears misaligned. During our recent trip I discovered that both galley cabinets- microwave and the one next to it- appear to be pulling out of the ceiling and separating. If I push up against the bottom of the cabinets there is a quarter to half an inch of play, and the pieces seem to come together.
Here’s the affected cabinetry with the area of concern circled.
In this photo you can see the misalignment of the cabinet door.
Close-up showing separation and gap between top of cabinet and headliner.
The only visible attachment screw is toward the front end of the storage cabinet, and it is solid.
I’m thinking there must be at least one more inside the microwave enclosure. I think I need to pull the microwave, but I can’t see how it is attached. There is a piece of stainless steel under the cabinets. If I remove that, will I find screws holding the microwave?
Any suggestions or personal experience? I’d also appreciate some general information about how the cabinets are attached to the fiberglass roof. What am I dealing with behind the headliner? Are there wood strips embedded in the fiberglass?
and put in, not put in, or stripped by the "butcher".
