MarthaA
P.S. Thanks for any comments you may have to my post!
Hello, We have a 2017 RoadTrek 190P – a Chevy van – with the same sagging cabinets discussed here. Pictures posted by Jon in AZ are pretty much like my cabinets.
* One difference in our case is the space above our microwave. See the picture I hope to post here. There is a black rubber filler or washer or whatever it's called which makes me concerned the microwave is actually attached to the wood above it. How would I get to that if there is a screw involved?
* Looking at the other spaces and screws, there are 2 screws below the microwave which I should be able to unscrew and then pull the microwave and the board it is sitting on. Sounds so simple. Except that washer in the space above. Has anyone seen this?
My goal for this project: to have the least stressful trip possible (set for July or more likely August) with the least amount of (preferably no) damage to our RoadTrek. I realize "least" is a relative term.
What if we left things as they are and went off on our travels? Could it get worse? What would that look like? I do see our RoadTrek as an investment and want to take good care of it as best we can.
The other option I see is to take the microwave out, at least temporarily. Is there any reason to think that once taken out we or someone else would have a hard time put it back in?
I don’t see how I could get it fixed up better before our trip. We just don’t have the time or ‘expertise’ to do it – at least quickly. And there’s not enough time to get someone else to work on it. I say that after reading this thread about what to do. I am wondering if anyone has updates to the problem!
Taking the microwave out for the trip is very controversial. We use it a lot and cook great meals that would not happen (as easily?) without the microwave.
found screws broken in the holes above the microwave.
real hard to get them out. got the middle one out and put a 2 1/2 wood screw with washer in it. added another 2 1/2 screw right behind it.
pre drill all holes and wood glue screw.
i made the travel post to help with road shock and loaded cabinetsView attachment 11551
I'm reading, trying to make sure I understand before comment - except THANK YOU for all comments and pics. What a great resource!
But just reading all this, first I have same question Jon in Az has: what are the screws in the top of cabinet screwing into? If the explanation is in booster's explanation (which is great), I'm afraid I missed it. I'm definitely rereading ...
I'll report back after I study my cabinets.
I had a similar problem in my 2016 190p. The bottom of the microwave cabinet was sagging to the point I took the microwave out while on the road because I was afraid it was going to fall out. I installed a piece of SS tubing under the cabinet to fix the problem. The SS blends in well with the surrounding area and will certainly be strong enough to never sag. I'm fortunate in that I can build things like this myself but any welding shop could make one for not much money. I could probably be talked into making another one if someone needed it. Drilling the holes in the cabinet was the hardest part, the holes on the left are very close to the bottom of the cabinet so a normal drill wouldn't allow me to drill them straight. I used a die grinder to drill the holes but there are other options out there to easily drill the holes.
what size tubing did you use?I had a similar problem in my 2016 190p. The bottom of the microwave cabinet was sagging to the point I took the microwave out while on the road because I was afraid it was going to fall out. I installed a piece of SS tubing under the cabinet to fix the problem. The SS blends in well with the surrounding area and will certainly be strong enough to never sag. I'm fortunate in that I can build things like this myself but any welding shop could make one for not much money. I could probably be talked into making another one if someone needed it. Drilling the holes in the cabinet was the hardest part, the holes on the left are very close to the bottom of the cabinet so a normal drill wouldn't allow me to drill them straight. I used a die grinder to drill the holes but there are other options out there to easily drill the holes.
That is 1x2x1/8 ss tubing. It's laid down flat and fits perfect between the light and front edge. 1x2 is complete overkill but it's what was available and I know it will never sag
Do you have a welder, if so size it so it fits your space and then weld.do you remember the size of the flat stock at each end? (sorry for being a pest) TY!@
