archie5463@gmail.com
Restoring 2001 Blue Road trek Popular need original striping if someone has a source for a manufacturer or original kit
I was looking at that site and can't find where you made your stripes.
Hello friend! I just bought the same exact roadtrek! I went to that website but I need to know the name of the tool that let you make those decals! I hope you’re still active on this site. I’m brand new to roadtrek and I’d love to compare notes I got a great deal on my ‘96 bc I have to drive to Detroit (from Dayton) and install a new alternator. Thanks! KaseyHere's what I did:
In the end I figured it was worth the $23 to try vinyl stickers from https://www.bannerbuzz.com/
They have a tool that let me create a banner that was 3.75" x 240". (Yes, 20 feet long.) The tool let me create long stripes of whatever color I wanted, so I "guestimated" what would look good as a replacement for the top stripe, ordered it and had a friend help me lay it down. Pictures attached, including one of the design tool with the stripe.
First, to be clear: I DID NOT strip off the old stickers! The original decals/pin striping was so sun deteriorated that when I took my pressure washer to the RV (even being careful), the slightest pressure would make the colored portion of the original decals come flaking off leaving the adhesive layer behind. I had no intention of buying a scrubbing disk and trying to remove it after what I was was required from watching videos! A few original spots would still be left behind, so I was fully aware that I would be placing a sticker on an uneven surface. I'll remind you: $25!!!
Well, it worked great in my opinion. I stupidly forgot to use the soapy water and squeegee technique to put the decals on - so it's not perfect. Close up, at an angle, you can see the imperfections, but I wanted it to "look good from 10 feet".
The biggest problem- one that might cause me to peel this off and try again with a new design - is that I *stupidly* thought that the company making the sticker would have machines that created nice clean edges. They didn't. I chose a white vinyl background, but made the blue color stripes stop and start on the edge of the strip. When they were cut, they weren't straight lines, so in the photos you can see how the top and bottom edges don't look straight - this is because the sticker wasn't cut properly. ($25!) On my top edge, the top and bottom pin stripes looked great - never peeled off - so I had measured and designed and ordered a strip that would fit between these two existing stripes. To be fair, their tool makes reference to a safe-zone that I should not have put a design on. The white of the vinyl decal would have looked almost invisible against the white of the RV, so I should have left a white bottom and top edge.
In summary, this $25 experiment looks so much better than the old peeled decal that I'm going to keep it this way and see how it holds up to rain, wind, etc. I'll report back.
I AM still active and those stripes still are perfectly attached. I also have recently added some Star Trek theme graphics to mine. I think it's tastefully done. I have the '96 Dodge model 190 Popular. I've touched every system, so I can probably offer a lot of advice on everything from replacing the cabin power converter to the under the hood isolator!
Pete that looks fanTAStic! I’d love to see more photos of your whole rig so I can copy it! Can you take a pic of the tool? I chat boxed with person at that website and she had no idea what I was talking about! Every replaced your alternator?
Not on the RV, no.
What kind of photos you looking for... inside or out? I stripped off the walls and rebuilt them in my battle against mildew when I bought it. If you search for threads of mine, you'll find it.
Pete is it a digital tool, like they provide the software or is it a physical tool that you can hold in your hand?
Kasey
The light can be found here: Amazon.comI would be interested to find out what you bought to replace the rear florescent light, please share.
Thanks!!
