TomF-ClassB
Anybody know if the gaskets for the three small windows above the windshield on the 1997 RT 190 Popular are available?
I used Captain Tolley's to seal the infamous rear window gasket leak on our y2k 200V.
https://www.amazon.com/Captain-Tolleys-Creeping-Crack-Sealer/dp/B003T6EJ9A
Thanks. It is ordered and on the way.
Great info, thanks. Looks like my first project this season will be to pull those frames from the inside.We own a 1997 Roadtrek 170.
One of our opera windoews leaked.
Be aware that the "outside" gasket does not prevent window leaks. Its function is simply to hold the glass in plave against the frame.
The glass is sealed against the frame with silicon or othe sutable material an d then the gasket is pressed into the frame to hold the glass in place.
We removed the screws from inside on the frame circumferences then carefuly removed the outside gasket, then the window from the frame.
The dried up sealer was scraped from the glass and interior frame then a fresh bead of sealer applied and everything put back in place.
Two years and many rain storms later, tight as a drum.
Mike Bee
1997 RT 170
formerly 89 VW Westfalia
Yes but their pricy.Anybody know if the gaskets for the three small windows above the windshield on the 1997 RT 190 Popular are available?
