Mardeldelmar
Will the fridge keep cooling while driving if it is on DC and I suppose the on board battery switched to ON? Thx
Would you like to regenerate the title as well as the summary?
What make and model of Class B do you have? I ask because some, like my 2006 Roadtrek 210P, did not have the fridge installed properly by Roadtrek according to Dometic directions. Because of this the fridge cooling was not optimal during any operation, from hooked up to 120v, gas operation, or DC. In addition fridge performance can vary from fridge to fridge based on how optimum the cooling fluid amount was. I have done extensive upgrade of my RM2554 Dometic fridge install, which has resulted in the fridge cooling pretty well for a gas absorption unit. This includes 12v DC operation while driving. Mine will maintain temp level while driving in hot weather and even lower the fridge temp in cooler outside temperatures.Will the fridge keep cooling while driving if it is on DC and I suppose the on board battery switched to ON? Thx
Thanks, I appreciate the input and will travel accordinglyThe fridge will operate on DC while driving, but the cooling capability will be seriously reduced over propane operation. At best you might maintain temperature in moderate temperature conditions... 60º or 70º, but in my experience anything higher, the fridge will temperature will gradually rise. I am not interested in a discussion about Propane safety, but I have operated my fridge on Propane while driving for many years without problems. Needless to say, I turn the fridge off before entering a filling station.
My dometic 3-way frig actually cools to a lower temperature on dc at the same setting while traveling than when we’re on shore power and using ac. The main concern is where is the sun? The sun has a huge impact on the cooling ability; for us it seems to matter more than temperature but we’re seldom in temps above 80.Will the fridge keep cooling while driving if it is on DC and I suppose the on board battery switched to ON? Thx
I do the exact same thing. I was a refrigeration tech many years ago, and IMO the 12V operation is useless. Many horror stories, at least from PleeasureWay users, of forgetting to shut it off, and that in turn killed their house battery. The first thing I did when I installed my new RM2354, was to disconnect the 12V option.The fridge will operate on DC while driving, but the cooling capability will be seriously reduced over propane operation. At best you might maintain temperature in moderate temperature conditions... 60º or 70º, but in my experience anything higher, the fridge will temperature will gradually rise. I am not interested in a discussion about Propane safety, but I have operated my fridge on Propane while driving for many years without problems. Needless to say, I turn the fridge off before entering a filling station.
Peteco is on target when he says it works ok for some and doesn't work sufficiently for others.
We have the 5 cf three way in our 2007 RT 210 and we normally are doing trips of a week or more. We keep the refrig really full and use only a little Camco fan that runs on two D cells inside to circulate the air. We put a couple of blue ices and a few cold Cokes in it when we fire it up on 120 or gas. We do this a couple of days before we are leaving and we pack it full the day before we leave. We have no trouble keeping the refrig in the mid 30s and the freezer compartment just a few degrees above zero when on AC or gas.
When we are going down the road, we run it on 12v just to maintain the temps and not hassle with turning off the propane when we refuel. Normally on a hot day the temp in the refrigerator will rise to the low 40s after seven or eight hours. That is about as many hours as we are going to drive in a day and then we switch back to gas. I define hot as mid 90s to a hundred.
We have never had any issues doing this and we bought our RT new in 2006 and still have it. I keep the door seals in good shape and the entire thing is stock just as it was when we picked it up new. I do check the refrig over carefully each spring being mindful of the gas jet, flu, etc.
SO, we are just lucky to be on the side of those that have had no problems. Camping, of course, we always use gas even if we have a plug in and only use the 12v for going down the road.
These Bs almost need a check list like you are flying a plane and I suggest newbies make one up. We have had Cs and gone down the road without incident on gas, just remembering to turn it off before refueling.
What do you do to keep them in good shape? Our freezer probably could use new seals, but I have not looked into how difficult that might be. 07C210P oem frig in use.I keep the door seals in good shape
I use a rubber and vinyl conditioner and protectant called 303 on the seals. Apply a few times a year.What do you do to keep them in good shape? Our freezer probably could use new seals, but I have not looked into how difficult that might be. 07C210P oem frig in use.
