Running an Xplorer Van Fridge on a Jackery 1000
Original Member Title: Probably obvious to most of you Portable solar battery
An RVer asked whether a Jackery 1000 could power the small Dometic refrigerator and lights in an Xplorer van overnight, either through the van’s shore-power cord or by plugging the refrigerator in directly. Members cautioned that an absorption refrigerator could drain the roughly 1,000Wh power station overnight or sooner, while a member considering a similar setup had a compressor refrigerator, which another member described as substantially less power-hungry.
The owner confirmed the...
jeana-ClassB
May 29, 2021
64
maine
Hi We have an Xplorer van just similar to a roadtrek with the usual small dometic frig. So if we stayed overnight at a rest stop/boon docked, I want to run the frig and lights off our Jackery solar generato.r It is a 1000 Ac output "3x110V 60 HZ 9.09A 1000 W max continuous 2000W surgepeak" It runs my big home frig for hrs . I cannot just plug in the van's frig though right? My original thought was to read by battery lights we have or phones and use the jackery for the frig but one cannot plug in the frig, can I - would I open the back? If I plug the usual wire from the van into the jackery and do not try to use the microwave that will work,yes? Or is there somewayto use the JAckery only for the frig??
It makes sense to me. I have considered doing the same with our 2012 RT190 and its two six volt AGM. The AC/DC Norcold fridge consumes most of our daily DC requirement. Reverse the driver side seat, place the portable lithium solar generator in the space between the seat and the van’s pedals, then plug the Norcold directly into the hidden generator.
My guess that we could stretch our off grid time from 3ish to 5ish days :cool:
I don't see any model on the Jackery site currently that fit that description so it must be an older version no longer sold, I think. Most likely a 1000 or so watt hour unit with 1000 watt output max with 2000 surge as those are pretty common specs.
If that is what the unit is, it is about the capacity of a 90 amp hour battery so not very large for current RV needs for many people. Jackery has also removed, it appears, all the detailed specs like charge rate max and recharge times, etc as finding enough time and a source to recharge the unit on the road is absolutely vital to be practical.
You Dometic is probably a 3 or 2 way propane unit, which are absorption technology so use lots of energy on AC or 12v and often don't cool as well on propane. I it is very likely it could kill the Jackery if it is 90ah overnight or even faster maybe. It will probably use as much or more than you home compressor style refrigerator. Sensfan would have better luck as he appears to have an AC/DC compressor frig that would probably use 1/4 of what an absorption frig will use. If you have a propane option, why would you want to use electric power? Or has the frig been replaced with and compressor 12v or 110v version?
This topic has come up before in various versions for class B use but rarely for running an absorption frig that I remember anyway. Mostly for supplemental power for all the now normal use DC loads which are much higher than in the past.
We don't have much information on durability or lifespan of the power banks either. Interblog, I think, used one to replace their worn out lithium setup and it did not last very long. There are few discussions on this forum that mention it.
I am not a big fan of portables, myself, as they are kind of a hassle to hook up to use, hook up to charge, find a place to carry and store them that is easy access. If there is room for a portable there very likely is room for a couple of batteries and an inverter/charger that is installed and easier to use.
Yes of course Duh we can run it on propane. Yes the Jackery is a few yrs old. I love it 1002Wh I do not know how to get/ install an inverter etc Sounds like $ I already have the Jackery Runs my pool filter etc at home and frig in power outage ( frequent here) Charge rate max I do not see in my manual . I see working time a formula,,charging times are 7.5 hrs from the grid( wall), 14 hrs from the car( but runs down the battery...) 2 solar panels about 8 hrs . electric generator about 7.5 hrs Thanks for the help and "reset" of my thinking DUh
I see no reason to be rude to booster for his comment; he obviously was jut trying to help you. Another reason to run your fridge on propane that he did not mention to you is that if your fridge is a 3-way, running it on AC or propane will result in MUCH cooler internal temperatures than the DC option. If you love your Jackery, that's great, but it's simply not a good solution to keep your food cold, period.
My first impression was rudeness also, but it can also be read as not rude based on the last sentence. I choose to think the best case option in this so no problem with me unless told otherwise.
Oh! I wasn’t being rude, but the duh was for me! Do you hate how stupid could I be? Why don’t I just run it on propane come on guys don’t be easily offended. You’re the folks that help we all help each other. Holy smokes I am. bothered by this —with no intention of being rude.
How heavy are now it got sent and not edit
Oh! I wasn’t being rude, the duh was for me! How stupid could I be? I thought what a dumb question I thought. Why don’t I just run it on propane duh. come on guys don’t be easily offended. I am very nice
Well then I'm sorry for my misinterpretation of your words. I wish you luck with keeping your fridge cool!
I am glad I guessed correctly in this. Jumping to conclusions based on semantics is too easy to do depending on how things are worded.
Thanks for replying
