I have made a remote switch for my Tripp-Lite inverter control, and want to install it in the entertainment cabinet. There are already wires running into that cabinet for AC power and cable, as well as a red and green wire. I've half heartedly tried to run a 12ga wire in one of the back access holes with little success.
I'm fine running the cable along the corner of the refrigerator/van wall, then up into the holes near the rear of the cabinet. What I've not figured out is how to get the wires out of the electrical or water bay nearby. I see I can run the cable between the two bays if desired, but I have not been able to remove the bay cover to try and make a notch for the wire.
Notes, wire is reference to a ethernet cable, which is the connection from the inverter to the remote. Also, what I'm calling the electrical bay is the location under the passenger side bed which houses the Tripp-Lite inverter amongst other things. And the water bay is what I'm calling the location under the passenger side bed which houses the water pump and water heater.
I removed the 4 screws that hold the hinged water bay cover that doubles as the foot for the passenger side bed. It seems as though perhaps the cover is screwed and glued on? Before messing something up I was hoping to get feedback on if/how one removes this cover, or tips on running the wire through the back of the electrical bay to the entertainment cabinet through the wall.
