Mike's correct. There are 3 common alcohols used for various things. Methanol (aka wood alcohol) is the lightest, most volatile and is toxic (causes blindness if drunk and was the principal concern of moonshiners or at least those that bought their stuff)). It's the alcohol generally used in gasoline mixes. Ethanol is the good stuff we drink and has a number of commercial uses including gasoline and windshield washer fluid. IPA, isopropyl alcohol, is not quite as volatile and is also used in windshield washer fluid, where it doesn't evaporate off the windscreen as fast the other two alcohols. It's also commonly available as "rubbing alcohol" and in disinfectants.
All 3 of the above are way too volatile to be used as or in an engine coolant. They'd "boil over". They're also quite flammable.
Ethylene glycol is a different beast all together. It's far more viscous, far less flammable and has a much higher boiling point. It isn't used in windshield washer fluids 'cuz it would just smear across your windshield, but it's ideal as an engine coolant/antifreeze when combined with a variety of anticorrosion additives.
So, if it is a methanol, ethanol or IPA based antifreeze, it's for the windshield washer. If it's a glycol based fluid, it's for the engine (and, if it's formulated without the toxic additives, it's labelled as plumbing antifreeze for use in winterizing the water systems in your RV)
