We have a series of dead battery in our Chevy after only a week or two of sitting that I tracked down to the Scangauge. The Scangauge 2 units had similar issues if the battery was disconnected and then reconnected unless you turned on the key so it could reconnect. The 3 is the same way, but it also would not reconnect from just turning on the key, even with it set to connect with COM instead of the default RPM sense. I got a hold of a good guy at Scangauge who had to go ask another person about it and then asked if it had a trickle charger on it or anything that would hold up the voltage like the coach batteries. Neither was our issue as no charger on it and the coach is totally isolated from van electronics, but he I might want to try the fix they use for those on trickle charge, RVs with coach and starting tied together , and hybrids.
It turns out there is a setting that is not in any of the manuals for the unit and not one you would intentionally go to unless for curious reasons. It is a setting for an auto activate of the unit based on voltage that will override the setting you make for COM or RPM with the engine not even running. If the battery voltage is a bit high it will go into an endless loop of coming on, trying to connect to the PCM, shut off, restart again. It sounded worth a try even though our voltage isn't overly high and it seems to have worked at least as far as I have tested so far. My guess is that it does not fix the battery disconnect/reconnect loop though.
The location of the setting is in Settings/advanced/compatibility and is a low/med/high setting. I changed ours to high.
I have seen multiple others in forums online that had similar dead battery issues, so there may be an issue with some/not all units being too sensitive to voltage.
And, I also discovered, totally by accident how to make the "double tap" turn on of the unit which I could never get to work right no matter how many times I tried. I was trying to get out unit mounting on the dashpad more solid and reliable and accidentally tapping the left hand side a couple of times. I must have hit it twice quickly because the screen came on. So the "double tap" for the Scangauge 3 is not on touch screen like our phones are, it is on the case like earbuds or hearing aids change things. Now I can get it on every time.
It is not a great benefit most of the time because it cycles off in about 10-15 seconds, but that would be enough to look at things like the tank or user trip when you fill up with gas to see the data there or reset the tank trip or user trip.
