Sea Foam Spray for Onan 2800 Carburetor Cleaning
Original Member Title: sea foam spray
A member with a well-running Onan 2800 Microlite asked whether Sea Foam spray through the intake, followed by removing and manually cleaning the carburetor bowl and jet, could handle the 500-hour cleaning without dropping the generator or disconnecting its fuel supply. One member argued that intake spray mainly addresses combustion deposits rather than internal carburetor fuel passages, while no one confirmed firsthand how easily the bowl and jet could be serviced in place.
Members...
Back in the day you could check the MSDS of Sea Foam and find the ingredients, this is no longer true. If memory serves me right the ingredients are Naphtha, Isopropol alcohol and pale oil. Pale oil is any light oil such as kerosene.
https://seafoamworks.com/wp-content/uploads/2017/01/Sea-Foam-Motor-Treatment-SDS-v20161205-ENG.pdf
Back in the day if a product was labeled ice cream it had to contain a certain percent of dairy products, if it did not it had to be labeled desert product, this is no longer true and much of the ice cream on the market is flavored corn syrup!
I have returned rough running due to apparent carb issues Onan 2.8 and 4K four or five times over the years to smooth running by also intalling a three way and pulling off an elevated to genny level gas can with a 50/50 Seafoam/gas mix for up to an hour (if it will run that long), and then doing the same thing the next day. If I remember correctly I think it took three tries once. Worked like a charm eventually every time for me.
I did use non ethanol fuel where it was available. Van ran very well.
I think it might be a good idea to use non-ethanol fuel when running the seafoam mix through the generator -- are there any well-known gas station chains that have it?
Ethanol gas only seems to cause issues when it is allowed to evaporate. I power my RV with a Honda 2200 and for the last couple decades with EU 2000. When traveling I use what ever gas is available as it gets used quickly and never gets a chance to dry up. Heading for home I run it dry and the last tank is always non ethanol even if I have to buy a can of it someplace. No problems yet.
Buying small amounts of non ethanol can be problematic if the pump dispenses through one hose. If the last sale was ethanol what is in the hose will end up in your container.
I think that is partially right about the evaporation and getting fully dried out because the gel gets thicker and more adhered and harder to get out of the passages. My understanding is that the primary issues are moisture and non compatible metal parts that make the metals corrode and then form the gelling good. Float bowls tend to breath with temperature changes and the small fuel passages to the carb throat see air all the time to provide both moisture and oxygen to the fuel and metals. I think there is also a possibility that once the metal gets corroded that first time, it will be more susceptible to recorroding after that because of the roughened surface of the metals.
I think it would be interesting to see if a pure, quick, evaporation of 10% ethanol full leaves a residue due to other things like phase separation.
Here in Minnesota all the pumps for the non ethanol premiums that I have seen are on separate hose/fillers so no issue with mixing unless it would be back in the pumps if they are used commonly and I don't know if they use full multiple pumps and such. Our 30+ year old snow blower and 25 year old lawn tractor have never seen ethanol fuel at all and they can sit all winter in Minnesota with no preservative and be fine in the spring. Our Onan would get back to surging in as quick as 3 weeks with ethanol in it and our shop/garage is temp controlled so no excessive temp swings.
What is the maximum amount of seafoam to non-ethanol gas ratio I can use? I assume the genny won't run if I use too much, but I guess the more you use the better the cleaning. So what is the maximum?
Seems I have read that bacteria can live in ethanol and harm metal. I am in FL and have not seen one hose used for both types of gas. Maybe it is not an issue anymore?
1 part Seafoam to 2 parts gas was recommended in this video.
Interesting video but does seem to be kind of heavily sales pitch also. Still very useful for all to see.
The evaporation explanation totally ignores the biggest issue we all face(d) and that is ethanol in the fuel that absorbs moisture and can corrode the metals in the carb itself. What they are describing is more the historical gas "going stale" type thing when the more volatile components of the fuel evaporate first and change the properties of the fuel over time and then the compromised fuel dries out. Less modern fuels without ethanol seemed to be a bit more prone to that kind of failure than the newer non ethanol fuel but that is just a guess based on we being able to leave non ethanol fuel in all the small engines without issue over winter months without issue over many years. Ethanol if fuels make it much worse and a much faster process that is different but still correctable in many/most cases with Seafoam.
The process he used will work, but IMO if the generator has plugged small passages and is still runnable but surging missed what I consider to be one step that can make the cleaning better and overall a faster way is left out. Letting it sit repeatedly with Seafoam in the carb.
Running the more concentrated Seafoam at as high as he did might make a surging Onan hard to start but not always so you might need some starting fluid to get it to start and get up speed. Then run it under load so you get as much fuel going through the passages as possible for the 20-30 minutes. Shut if off and let it sit overnight and repeat the process until it smooths out which may take multiple times. Probably best to do at least one or two more days of the cleaning after it smooths out if it was really running poorly originally to get as much cleaning as possible.
At the 1 part Seafoam to 2 parts pure gas I am not sure that the engine oil will not be contaminated with it, and if it is not fully combusted enough to clean the rings it might not be. Changing the oil afterward might be good insurance on that. I am also not a fan of anything like Seafoam in the oil as an additive as modern oil recommendations have gone to thinner oil already so anything that dilutes can affect the lubricating qualities is not a good idea, I think.
Fogging the cylinders is a good idea for over the winter but be sure not to overdue it so it washers all the oil out of the rings. If the engine is in decent shape and doesn't burn oil or have bad compression probably the best thing is prevent messing it up trying to make it better. Seafoam is stated to be an upper cylinder lubricant and it is a better lube than gasoline, but it is not anywhere near as effective as a lube as engine oil is because the oils in it are very, very thin. Above the rings, yep, no problem in and below the compression ring, not great IMO.
Are you saying 1 to 2 is too much seafoam? What ratio do you think is right?
Many years ago, and if my memory serves me correctly, I had a sticky lifter in a vehicle I had. My mechanic gave me a bottle of seafoam and told me to dump the entire bottle in the oil, run it for (I think) 100 miles, then change the oil. It made the oil have the consistency of water, but it did solve the lifter issue and had no other issues with that engine for the rest of the time I owned the vehicle. It was my introduction to seafoam as I hadn't heard of it at the time and he said that he has some customers who add a can with an oil change. Now emissions and things have changed in the years since, and I'M NOT SUGGESTING ANYONE DO THIS (I'm not a trained mechanic), but do want to mention it's possibilities. I have added the ounce to oil as suggested on the can and used that as a cleanse to the oil system in several vehicles we've owned, including our 2008 Roadtrek 6.0L without issue.
In the past, the lifter fix was always worth trying, but of course we rarely got an engine that lasted past 100K also even on the thicker oils. An ounce added to a modern engine isn't any issue a big deal at all on most any engine and it the past it would have been much more than that and at least on can. Some even dumped a gallon of kerosene in and ran at fast idle before every oil change. We did the kerosene trick to a very sludged up Plymouth slant six to clean it up and it worked, but after a while when it had 20 weight oil in I drove to fast for too long and it lost the lobe on camshaft that ran the fuel pump. That was a big tick and took a new camshaft to fix as the electric pumps were not very affordable to me then.
Has anyone used the sea foam spray to clean the carburetor on an Onan 2800 microlite for the 500 hour cleaning? Just spray it into the air intake with the generator running; then, with the generator and main fuel line in place (no longer running, obviously), remove the jet and bowl and use the spray to clean them? It seems like it might be easier than dropping the generator or disconnecting the fuel line to run sea foam/gas mixture through.
I made the mistake of not exercising my Onan for 9 months and, of course, it wouldn't start. Online instructions advised cutting the fuel and installing a cutoff valve. Take the generator end of the line and shove it through a hole in the lid of a Mason jar. Fill the jar 3/4 with gasoline, 1/4 with Seafoam. Start the genny. It will sputter and spit, but a wonderful cleaning job is taking place. My Onan hasn't run as good in years. Dave W
Is there any reason to elevate the gas can to the level of the generator? I think it does have its own fuel pump.
Also, I am still not sure about the ratio here. The answers have varied a lot. Isn't 50/50 very high?
IMO, yes it is a very high and if the generator stills runs, but not very well, it probably isn't necessary.
I can't imagine needing nine 8oz cans of Seafoam to 1/2 gallon of gas.
I don't think it would hurt anything, but as mentioned early getting it to restart again if you do the let is sit overnight routine might be very hard and there is also the mentioned oil dilution possibility especially if it is really hard to get started. There isn't a lot of oil in a 2800 Onan so it doesn't take much to contaminate it.
When we still had our Onan, and cleaned and/or preserved for overwinter I used the 2oz per gallon and it worked fine for both cleaning and storing for us.
I would think that 8oz per gallon if it still runs would be fine, and 16oz per gallon if it is very clogged up, should be plenty concentrated. From your original post, it sounds like you are more doing a minor clean up service on a unit that is still running well so probably no reason to go to go overly concentrated. If it were mine, I would use the 2oz per gallon concentration and with a couple of overnight sits between 20 minute full load runs.
OK. One other thing: I do not have ethanol free gas available, but I do have a fresh 32 ounce can of "trufuel" -- would this work as well for this purpose? I could just an ounce or two of seafoam to the can and feed the new generator hose directly into that.
I would certainly think so.
