engnrsrule
Our 2006 RoadTrek Adventurous (Sprinter 2500) was originally equipped with two smaller passenger seats. These are rarely used since the unit cannot realistically sleep more than two. I just completed some changes that make better use of the space, which as we all know is a premium in a Class B.
The swivel/reclining buckets are mounted on foundations that are through-bolted to the floor. Removal of the retaining nuts from underneath is a challenge. The bolts are welded to the seat foundation or seatbelt anchor. Dummy bolts were placed in each hole to seal the hole and permit return to the seated configuration in the future.
Each seat foundation has a finished enclosure. On the passenger side, the enclosure was left in place, since it also houses the black tank and fresh water fill. (not to be confused). The seatbelt clicker anchor was removed, and the seatbelt disconnected at the top and stored in the enclosure with the retractor. The hole in the top of the enclosure was covered by relocating a 2-drawer cabinet that is normally located in the back between the couches when not made into a bed. This provides a small elevated table top that can be used as a seat to tie shoes or casual (parked) seating. The drawers provide convenient storage for keys, flashlights, tools, or “take with you” items that previously took up space in the kitchen drawers.
On the drivers side the enclosure is too small to be of much use so it was removed. In its place I built a storage bench that is “seat height”. The prior enclosure also stored the forward interior table top, and this function was preserved with the new bench. The sides were made from 5/8” sanded beach plywood, which was closest to the interior cabinetry color and grain. I made the top from 3/4” red oak cabinet grade plywood, with a solid oak edge cap to hide the plywood edge. The wood was finished with Minwax “Natural” and is a very good match to the existing interior finish.
I wanted to retain at least one additional seat-belted position. I relocated the clicker anchor from its position inboard of the old set enclosure to the forward outboard seat foundation hole, and left the belt and retractor in its original position. This created a sideways belted seating position, similar to the jump seat in extended cab pickups. Back support is provided by temporary throw pillows, but I may install something more permanent.
I decided to use the storage bench as my internet nerve center. I installed a “puck style” combo WIFI/Cellular/GPS roof antenna and ran the cables to the bench. I installed a King Router/WIFI extender to establish the rig’s WIFI and connect to campground or moochdocking WIFI when available. I added an older Verizon Jetpack to provide a cellular data plan. This is adequate for our needs, and in theory should work while rolling. I also upgraded to a smart Roku TV and it works great on the RV system.
Check out the pictures…
