Most solar controllers are programmable to match different types of batteries. I assume you are referring to the house battery on your RV. The controller will augment your onboard charging system, so there won't be a separate battery for the solar system.I need to make sure i have the correct solar battery for the Go Power controller. I don't know where it is located to look at it in my 2019 Coachman Beyond 22D.
