You have a 200 Watt solar panel, you could not carry a 200 amp panel!I put a Bluetti 200Max in my 2000 Roadtrek 190 Popular into the closet. You can charge it while driving with an adapter to the 20amp outlet on the dash. It has about a 4000 surge capacity. I can run the A/C and microwave at the same time. The limiting factor is for how long. The A/C will run for about 1.5 hours. I also have a portable 200amp solar panel which helps prolong the battery life. Overall, between the propane and this system I can boon dock for a couple of days, especially if I don’t use the A/C much.
I installed an 800 watt total set of solar panels and I have 3 LiFePo batteries and a 1000 watt charger/inverter runs half my shop
Folks basic ohms law, a motor takes 746 or 800 watts weither on 12 V DC or 120 V AC its the watts, no energy savings either way, its all about Watts. In fact running on 12 volts requires a huge wire size to carry the load. Horsepower to watts (W) conversion calculator
