I recently took delivery of a 2019 PW Plateau TS. It does not come with a spare tire. Only an inflation kit that includes a gel to plug the hole in the tire for a short distance to a repair facility. The problem is that I’ll be traveling through Canada and Alaska and a tire repair facility may hundreds of miles away and the gel, if it works at all, is not designed to hold for more than what PW says is about 40 miles.
So, I am interested in adding a spare tire carrier to my Sprinter van. I intend to keep the back doors free of obstruction to allow opening to access items and safety. A tire carrier mounted to a swing mounted hitch would be a solution, except that I also intend on mounting a storage container in that same hitch receiver.
So, I’ve found two alternative choices. And you may have thoughts on these choices or other recommendations.
• Mount the spare tire to the back-left door. See below for info.
https://www.sprinterstore.com/product/sprinter-rear-tire-carrier-ncv3-spare-wheel-carrier-for-2500/
Problems: The mounting of this carrier is permanent and will require holes in the door. The extra weight of the mount, tire, and wheel may over time damage the rear-left door hinge? Will require any hitch mounted unit to clear the depth of the mounted spare tire. Back left door may not be opened 180 degrees. Difficult to install.
Advantages: Usable with or without hitch in use for other units. Back doors work as normal.
• Use a hitch extension that includes a spare tire carrier.
https://www.etrailer.com/RV-Cargo/Roadmaster/RM-195225.html
Problems: This extension again requires any additional hitch mounted units to clear the tire. While this works great with a straight hitch, when using a swing hitch to clear access to the back doors this combination has greater weight (Swing hitch + tire carrier + tire and wheel + storage unit) and therefore less storage weight capacity.
Advantages: Easy to install. Easy to swing away from doors to access rear of motorhome.
You comments and thoughts are welcome.
