Got some data. Brought SOC down to 48%, left it with no load overnight, and did some testing this afternoon. Attached is a PDF with the data. Max alternator output was 150A, rapidly tapering down. First test was 12:40 to 1:20, then our dog had a vet appointment, so I stopped. Restarted later in the afternoon. Hopefully this data makes sense - I'm not sure what's up with the total alternator Amps vs House Amps...
The Charge# vs AH required to 100% ("AH" on the trimetric) #s seem to pencil out right with the 375AH AGMs. In other words, the trimetric seems to be calculating the %Charge correctly.
The alternator is not putting out the juice I expected, even with 50%
charge to start.
Might see if we can move the last portion of this thread over to my first one: https://www.classbforum.com/forums/f23/suggested-high-capacity-alternator-04190p-11671.html.
Appreciate any and all feedback!
That information tells us a lot. The biggest thing is that your batteries are not anywhere near full. You returned amp hours to what you thought was full, but it wasn't. Did the trimetric fully charged lamp (I think it has one) come on?
To be totally full you would need to be at 14.4v and under about 2 amps, but most systems can't go to that detail. You are at 13.9 or so and just under 50 amps so you are probably at only 75% full.
You need to get your voltage up and the absorption time longer. Once you get to the right voltage you will need to go to 110-120% amp hours returned to be back at where you started the discharge because of charge efficiency. Right now by charging back only 100% amp hours, you are getting less full on every recharge cycle.
You will likely need a remote regulator to be able to get much better overall, but a higher setpoint internal regulator would help some, but if you have two alternators you have to buy two, but the external like a Balmare can run two by itself.
