What voltage are you using?
Have a 12V system, and considering upgrading. I'm well versed in the electrical side of things. Smaller wire gauge for higher voltage etc. My question pertains to what you are running off of it inside.
In my current setup, I have a number of things running directly off the 12V, and only use the inverter for 3 kitchen appliances when needed. Microwave, Air Fryer, and Toaster. Almost all of my DC equipment has a 12V/24V input option.
To my understanding of what's out there, if I take the step up to 48V, nearly everything will need to be run through an inverter. There are at least a few 48V AC split units, but everything else will need to be via the inverter to 110V, or a buck/boost transformer down to 12/24V depending on amperage requirements.
