Updating video reception in older Class B with coaxial cable setup
Original Member Title: Updating video reception in older Class B with coaxial cable setup
A member with a 2013 camper van asked how to move beyond coaxial cable TV hookups to newer viewing options. Members suggested a Wi-Fi-capable smart TV for streaming services such as YouTube TV, or adding a Roku stick or Fire TV Stick to the existing television.
One member reported using a Roku TV with a King router and a cellular hotspot costing about $50 per month, later replacing an older Verizon Jetpack with a refurbished, unlocked Netgear Nighthawk M6 using a Verizon SIM. That...
Brewbren
May 17, 2026
28
Albuquerque
I've seen some discussion on this site regarding ways to get tv reception without having to rely on coaxial cable hookups. Any good sources of how-to to convert my 2013 camper van with cable tv to a more contemporary technology? Is this the correct forum? Thanks.
On our 2008 van we replaced the tv with a newer smart tv that can connect to WIFI. You can then use streaming services such as YouTube TV. An alternative option is to add a Roku stick or Firestick to the older tv.
Thanks DaveBad. I'll look into those options.
I did like you, but found a roku TV. When I set it up it automatically applied my other roku setups on my account to the new TV. I have a King router and get Internet from a mobile hotspot for about $50/month. Good connectivity even when rolling down the highway.
To test proof of concept I bought a 15 year old 4g jetpack on eBay for $13 and bought a Verizon SIM for it. It worked pretty well while I learned more about mobile internet. I heard that there was a 5g chip set new on the market that would become the standard. I set sights on the Netgear Nighthawk M6. They have the Qualcomm Snapdragon X62 5G chip set I wanted. That hotspot also had two other features I wanted - dual MIMO antenna ports (for my external roof antenna, and a CAT5 port to hardwire to the router. (It can also serve as its own router, but I preferred the King router, which I could easily switch to a host wifi if available). The M6 was around $1200 when first out, and it was a T- Mobile device, but after a year I was able to find a reconditioned and unlocked one for $150. I put the Verizon SIM in it and it works fine. Better coverage and more stable than the jetpack. (I tried to update the equipment section on myVerizon, but Verizon won't recognized devices not on their list so they still show the Jetpack. This does not impact functionality.)
What kind of mobile hotspot are you using?
Right now, I'm not using any hotspot. I have the capability to use my Moto G5 phone as a hotspot (I think?) and have not used my TV setup at all since buying my camper van a few months ago. So if you have any suggestions as to what type of hotspot to get, or any suggestions for how to set this up (I'll probably just have to completely replace the TV with a smart TV and not use the cable connectors anymore) but am otherwise a babe in the woods regarding the technology for establishing remote TV reception in my camper van.
OK, I just saw engnsrule posting from last night and will go over that right now. After I get that info digested, I can let you know which, if any, direction I go in to establish mobile internet in my van and set it up for TV reception as well as internet reception for my laptop/phone, if that is also possible following the info that engnsrule provide.
Thanks engnsrule. I just saw this response after responding to the query from Irish Calexico regarding hotspot being used (none yet). I'll look into what you did and see how I might follow some of these same approaches to setting up mobile wifi and internet in my van.
The problem with many hot spots and cell phones used as hot spots is their inside antenna location. You want your cellular antenna on the outside, on the roof.
An altenative to hot spots is a "cellular router". These routers are just like your home router with the addition of a built-in cellular transceiver that connects to your roof-mounted MIMO antenna with 4 coaxial cables. Attached is a photo of our roof with the small white round object in the very front being the antenna. Several companies manufacture these routers. We chose a Pepwave MAX BR1 Pro 5G. (There are cheaper units to this ~1K$ solution)
Thanks Winston. Sorry for the delayed response. Had to deal with a leaking AC gasket on this puppy!
I'll consider this info in working out my best approach to upgrading my cable system to a fully mobile-friendly one!
