Winston-ClassB
Well Booster, there will be no 10th Year Annual Lithium Report. After losing 30% of our 500ah GBS lithium pack capacity over its 9 year life, we decided to replace these 20-100ah cells with 8-Eve MB31 cells (314ah each) for a new pack ‘theoretical’ capacity of 628ah.
We are continuing to use our original Elite Power Solutions BMS, now reprogrammed for the higher pack capacity and fewer cells. One issue, however, is a difference in maximum charge voltage - - 14.2v for the GBS and 14.4v for the Eve cells. As our Elite BMS balances at the 14.2v level, we shall continue using the 14.2v when balancing our new Eve lithium pack. And since our Eve pack retains 80% SoC when charged to 13.4v (leaving 500ah usable - - the size of our original GBS pack when fully charged 9 years ago), this will be our normal target charging level. Only if venturing into the unknown boonies for an extended period will we have need to bump this charge level by 0.1v or 0.2v to recapture that last 100+ah of capacity.
In anticipation of this lithium project, we purchased a new ‘gadget’ - - a FNIRSI HRM-10 battery voltage and internal resistance meter. Booster, you’ll be jealous - - we have no idea its actual accuracy but it purports to provide cell voltage resolution to 0.1mV! Even if inaccurate, we assume it will give us 2 more decimal places ‘comparative’ resolution over our Fluke 177 (with its 10mV resolution).
Our new Eve cells clocked-in at ~0.22mΩ (the spec is for 0.18mΩ +/-0.04mΩ). We tested our old GBS cells - - expecting extremely high values - - but discovered they were only ~0.88mΩ. Considering that these old GBS cells were only 100ah (as contrasted to the Eve cells at 314ah), we assume, even when new, that they would have had a correspondingly higher internal resistance.
Finally, we performed our “Zero’th Year” capacity test. We charged (and mostly balanced) the pack to 14.2 volts. Interestingly, Eve specs the full discharge voltage to be 2.5 volts/cell (10 volt pack voltage). This number is considerably below the 2.8 volts we’ve been using over these past 9 years when measuring our GBS cell capacities. So our ‘new capacity’ tests might be applies-to-oranges when compared to our past efforts - - we charged to 14.2 (not Eve’s 14.4 spec) and discharged until the lowest cell reached 2.5 volts (again, not 2.8v as in the past). The result: 643ah capacity.
