Using Tow/Haul Mode Full-Time in a Chevy 3500 Van
Original Member Title: Does anyone keep their tow/haul button engaged at all times when driving?
Members discussed whether a built-out Chevy E3500 should be treated as “hauling” enough weight to leave Tow/Haul engaged all the time. Some RVers with heavier builds said they use Tow/Haul often or full time because they prefer the shift points, hill performance, and downhill engine braking, with little mileage penalty in their own vans.
Others said Chevy Tow/Haul behavior can vary by transmission and programming, and may raise shift points, affect converter lockup, reduce fuel economy, or...
teslasmuse
Apr 5, 2026
84
Montana
I'm having a discussion on a vanlife thread on reddit and there seems to be some confusion, my research on my Chevy E3500 says only engage if I'm carrying extra weight and towing, but is the van build and all of my possessions the extra weight? Should it be on 24/7?
I have never heard of anybody doing that in the Chevies.
The tow haul usually raises the up shift speeds and reduces converter lockup, but I haven't specifically looked for that in tow/haul for the 6 speed. Both of those will give you marginally better acceleration but at the expense of gas mileage and engine and transmission heat.
On our van, we use the tow/haul button differently by a bit because it is reprogrammed to keep the 4 speed transmission cooler by locking the converter more of the time and at lower rpms, which is the opposite of what is was stock.
We are in a 10 speed Transit and it changes the shift points and duration of each gear and also shifts it into lower gears on downhills to help with engine braking. Effect on gas milage is marginal but performance is significantly better. As the previous poster mentioned not sure how it works with a Chevy.
I always drive my C14RTRanger with TH engaged. I prefer the shift points, especially when driving in the hills. Even on what appears to be flat terrain you are often actually going up a slight grade. The only drawback is the loss of gas milage and I probably wouldn't use it in snow or ice as the shift points can be a bit more abrupt.
I operate our 2012 six speed Chevy 3500 on manual setting for climbing and descending hills. I monitor RPM and transmission fluid temp while simultaneously reading the hill grade and its changes, I downshift prior to losing engine RPM and changing gears, as needed, throughout the climb. Reverse logic takes over at the peak and during descent, which, as previously discussed in another thread, minimizes braking, which in turn reduces or eliminates rotor wobble.
I found that our 2010 210P does very well with TH engaged. Same comment as above about rolling grades. In our case there's barely any mileage loss and the van performs very well. Any sort of incline I now engage TH - big difference, on declines I use the manual control.
“ TX … Any sort of incline I now engage TH - big difference … "
Please describe any hill climbing vehicle performance variations between when your TH is engaged vs.when your manual position is engaged and you make gear changes during the climb.
I've had my 190V Chevy for 20 years. I only use the Tow/Haul when pulling my boat or climbing a steep grade. Otherwise I don't. Save your transmission.
GR “I've had my 190V Chevy for 20 years. I only use the Tow/Haul when pulling my boat or climbing a steep grade. Otherwise I don't. Save your transmission."
Interesting comment. I’m not tech savvy, but its been my belief that using Tow/Haul on my 2012 Chevy 3500 6.0 litre/six speed transmission for hills means (1) fewer hill gear changes and (2) higher RPM numbers both during and between the gear changes.
Agree; disagree?
For those that use TH how does the downshift work when going down hill? I have 2009 210 with TH and I used it going up hill and I do notice the higher RPM shift points but when going downhill it doesn’t downshift when I brake. I also have a 2005 Chevy avalanche with TH and I can’t get it to automatically downshift when going down hill. What parameters have to be meet before transmission downshifts?
If your van build is heavy and it stays loaded all the time, then yeah you can basically treat that as constant extra weight. A lot of people leave overdrive off only when towing or climbing hills though, not 24/7.
Just had my transmission flushed and serviced by the local transmission experts and I asked about the tow button and they said I only need to use it on big big hills that require a long climb, or if towing.
I disagree. My van weighs in at almost 10k lbs which is like it's constantly towing something.
We just finished a 6k mile road trip to northern USA, from flat roads to moderate grades. I used tow mode almost constantly with great improvement in driveability. Mileage was steady at 16.5 average for the trip. 6.0/6L90. Downshifts were significantly reduced, especially over moderate grades.
I think that I contributed to the converter clutch failure about 20k miles ago by not regularly using tow mode. The shop that did the rebuild recommended using tow just about everywhere, primarily because of the van weight.
Going into towns from highway speeds I'll disengage tow just to avoid a harder downshift, but will typically use it even in town. If there's a steep downhill I'll pull over and use manual mode to use engine speed to help control descent.
Certainly anyone can choose their own preference, for me the results have been great.
We don't have a 6 speed so perhaps they are different, although the programming of the pcm I saw didn't look like it.
For the 4 speeds and I think for the 6 speeds also, tow/haul just raises the shiftpoint speeds and converter lockup speeds, and yes that will give better acceleration improvements and prevent downshifting from the predominantly low load desired overdrive ratio gears. It will cost some mileage most of the time and in the 4 speeds can contribute to transmission overheating because the converter is not locked up as much of the time. The 6 speeds don't have that issue because they are locked up nearly all the time.
A lot of the 6 speeds have had converter clutch issues, so you aren't alone on that. Hopefully, aftermarket dual a triple disc clutches and maybe higher application pressures can solve that issue for the 6 speed owners.
I drive my 2012 6-speed chevy 3500 in manual mode for the ongoing challenge of multi-tasking, which requires full time attentive monitoring. I continuously monitor RPM, speed, road elevation changes, traffic pattern, and any other pertinent factors. IMHO, my gear changes and fuel efficiency are efficient. Maybe this is because I learned how to drive on a standard shift vehicle :)
The rebuild included a new bellhousing, pump, with billet faced converter and some internal Sonnax upgrades along with clutches, seals, etc. In particular the 5/6 clutches were burned along with the converter clutches. Common failure point.
Yes, tow mode changes the shift points but more importantly it locks the converter early which works well with increased shift points and reduction of slippage or constant shifts.
Regarding the mileage, I was surprised that there was no real loss, historically the van gets 16.4 mpg over all terrain, this time was about the same at 16.5.
Again, I'm just stating my perspective from driving experience. It's made a good difference to me.
As I mentioned, at least the 6 speed used in pickups which was the only one I could find to look at, even in drive they lock the converter nearly all the time. I think I may have shift and lockup point screenshots on one of my old threads. I will look for sure.
The big benefit you get with tow haul in the six speed would be in higher shift/downshift speeds so van can pull ht heavy weight of our vans with constantly searching for gears.
The Sonnax parts (they make good stuff, no question) may increase the pressure on the converter. I think all the six speeds are "constant slip" style that let a small amount of slip to happen all the time to reduce chatter but not certain on that. They require the high carbon special converter disc to be able to survive that feature.
2015-6speed-normal-shift-points-jpg.715774
2015-6-speed-normal-ttc-jpg.715775
2015-6speed-tow-haul-shift-points-jpg.715776
2015-6speed-tow-haul-ttc-jpg.715777
Here are the shiftpoints and lockup points for the 6 speed pickup truck 6.0L I found. It can be kind of fun to look at it and compare to what you see/feel as you drive it. It shows quite a lot of similarity with it all moved to higher rpms with both locked almost all the time in use. .
At most throttle positions, the converter lockup is quite a ways below the shiftpoint and the release is even lower so it will stayed locked under those conditions, it you close the throttle bit it will move to another cell based on the throttle position.
By doing it this way, you get the maintain power available by keeping higher rpms in tow/haul and also keep the low converter heat generation by being locked when compared to a higher gear no lockup situation.
This the big difference between the 6 and 4 speeds in that with the 4 speeds you wind up with higher shiftpoints so the converter is locked less when you need it keep the heat down from the converter.
